Popping the Clutch
Old Dec 30, 2008 | 07:53 PM
SebtownRx8's Avatar
75shot55fueljets=GOBABYGO
Popping the Clutch
So i flooded her today 2nd total time flooding the car and i did the usual and it just didn't start. after even trying to jump start it for like 20 mins i just dont want to hear that starter noise anymore. so will popping the clutch in 2nd or 1st for sure start a really flooded rx8??? thanks in advance. and yes i read the threads saying it will work but they didn't say if it was flooded or not thanks.
Old Dec 30, 2008 | 07:57 PM
staticlag's Avatar
The Professor
It might depending on how fast you can get it going, surest way is to hook up the tow hook and pull start it.
If that's too much work I have had success with pulling one of the plugs, putting like 10mL of windshield washer fluid in the engine and starting her regularly.
Old Dec 30, 2008 | 08:00 PM
Jon316G's Avatar
Grasshopper
I just de-flooded someone's engine today using washer fluid.
I injected it into the maintenance ports on the intake manifold using the washer fluid's rubber hose from the reservoir.
Old Dec 30, 2008 | 08:14 PM
SebtownRx8's Avatar
i am just boggled by this, so i totally see the hose you can un hook, and just tap the washer fluid on the blinker and its putting water and the cleaner in there, after that like what just start her up?
Old Dec 30, 2008 | 08:24 PM
Jon316G's Avatar
Grasshopper
  1. Basically disconnect the hose at the elbow
  2. Remove the rubber caps from the maintenance ports
  3. Insert the hose onto one of the maintenance ports
  4. Turn the key to 'ON'
  5. Give it a couple "mist" squirts
  6. Insert the hose onto the other maintenance port
  7. Give it a couple mist squirts
  8. Turn the key off and reconnect the caps onto the maintenance ports.
  9. Start it normally
Now it has never started right away for me, but you should hear a major difference when cranking.
Never crank for more than 10 seconds (though I have gone a little longer when it was close to starting).
Once it starts, it'll sound rough so don't be scared.
Just give it slight gas (no higher than 2500RPM) to keep it going.
After roughly 10 seconds, let it idle for awhile (maybe 10 minutes).
Old Dec 30, 2008 | 08:35 PM
SebtownRx8's Avatar
sweet dude i'll give this a shot right now. really dude thanks been yelling and smoking cause i'm so pissed off, will give this a shot now.
Old Dec 30, 2008 | 08:41 PM
heyarnold69's Avatar
Rotary wanabee
wow.... How does one even think to put windshield washer fluid in
Jon316G's Avatar
Grasshopper
Good luck SebtownRx8
I attached these pics in case someone doesn't know where the maintenance ports are.
Attached Thumbnails Popping the Clutch-maintenance-ports.jpg   Popping the Clutch-maintenance-ports-2.jpg
Old Dec 31, 2008 | 01:45 AM
SebtownRx8's Avatar
great pics thanks
Old Dec 31, 2008 | 03:49 AM
DOMINION's Avatar
I don't buy Kool-Aid
It drys fast unlike water wetting the spark plugs. Them parts is also what you use to de-carb your 8. The bitch is un-hooking the plug behind the intake uhhhh ...
Old Dec 31, 2008 | 07:04 AM
Jon316G's Avatar
Grasshopper
Yeah... those plugs are a little tough at first.
I used pliers to twist the caps back and forth while working them off.
theblinkof
Oct 4, 2023 05:24 PM
Racingjunkie
Sep 29, 2015 05:05 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
