ASAP i need a new battery..,Whats best to run with the car+ 1000 watt amp + others...
Old Dec 29, 2008 | 04:26 PM
lokaldisruption's Avatar
04 Grey
Exclamation ASAP i need a new battery..,Whats best to run with the car+ 1000 watt amp + others...
Best Battery to run along with car...1000 watt amp, undercar neons, misc other neon lighting...?
Name the Brand and where to get them...
Please Help. Need to buy it in less than 30 minutes.
Old Dec 29, 2008 | 04:35 PM
nuke0907's Avatar
Never Blend In
are you serious with this thread? 30min?
Optima Yellow top 35 series. you can get them from an auto parts store. hopefully they have the right size and reverse post terminals.
Old Dec 29, 2008 | 04:37 PM
04 Grey
what u mean reverse post terminal?
Old Dec 29, 2008 | 04:41 PM
nuke0907's Avatar
Never Blend In
if you look at most batteries the posts are on opposite side than what the 8 comes with. this means you have to get a reverse post battery.
when you look at your engine bay from the front the positive terminal is in the back on the right side. the negative is in the front on the right. make sure you get that configuration cause most batteries are not like that, they are the other way around.
Old Dec 29, 2008 | 04:54 PM
04 Grey
ah thank you so much=) i will look for that.
Old Dec 29, 2008 | 04:56 PM
heyarnold69's Avatar
Rotary wanabee
5 farrat Cap. solves your problems. Make sure you have a cap!
Old Dec 29, 2008 | 05:18 PM
dshiznit1489's Avatar
Formerly Polak Graphics
Optima Yellow Top.
Old Dec 29, 2008 | 05:37 PM
ZumnRx8's Avatar
RX8 & RX7 owner
^^^^^what he said
Old Dec 30, 2008 | 01:08 AM
jordanjerome's Avatar
ruthless8
ok so I know the Optima Yellow top is great but I am running a 2000 wt amp with a 10 farad cap..... Is the Red Top sufficient for this since it was what the car came with from the guy who sold it to me. BTW he sold it to me with only 5k on the motor because he did not like the Gas Mileage. Sorry for the spelling,m long day
rotarywanker
Dec 8, 2022 05:56 PM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
ei8ht
Aug 21, 2017 09:08 AM
