Burnt smell
Old Dec 21, 2008 | 11:21 PM
chris6558's Avatar
Burnt smell
I just bought an rx8 o7 and has a funny burnt smell when i pull in the garage! Is this normal?? Any info would be great! I thought it was the armour all that the dealer sprayed all over the engine compatment but its been a month and still have the same smell
Thanks for the help
this car is great!!!
chris
Old Dec 22, 2008 | 12:18 AM
icyur2's Avatar
Shonen
Funny you mentioned it, but mine does too! However, if you are using winter tires during this season, it is because of the tread that makes this smell...
Old Dec 22, 2008 | 06:27 AM
Go48's Avatar
Check for the remnants of a burned plastic bag on your exhaust system. Fairly common occurance. If that's what is causing the smell, it will eventually go away after the entire bag is burned away.
Old Dec 22, 2008 | 10:45 AM
chris6558's Avatar
no plastic bags i checked for that! Is it something I should bring it back to the dealer for?? Its still under warranty
Old Dec 24, 2008 | 09:44 AM
mazdaverx7's Avatar
RX-Heaven
my fear would be that if you brought it to the dealer and they found nothing wrong, would they charge you? what does the smell make you think of? burnt oil? burning rubber? melting wires? burnt coolant?
Old Dec 24, 2008 | 10:10 AM
ShellDude's Avatar
weeeeeeeeee
I suspect you're picking up the sweet scent of unburnt fuel, oil, all kinds of other goodies compliments of the POS cat and high temp exhaust.
Translation: completely normal
Old Dec 27, 2008 | 05:05 PM
chris6558's Avatar
smells slightly like oil but its not burning an abnormal amount of oil! Just smells a little different than most cars! Think it is normal but just wanted to see what you guys thought
thanks for all the info
Ovr-9000
Apr 7, 2016 11:19 PM
Quiggs321
Sep 30, 2015 05:34 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
