which engine?
Old Dec 21, 2008 | 02:51 PM
kseer's Avatar
which engine?
ok, im getting an 04-05 rx-8...im going to swap the motor out (yes i realize the costs) idk what to go with thoug..im new to the whole rotary..i know their badass tho..so i looked and jdm has a cosmos 20B twin turbo full engine with auto tranny for 4K, i want enough power to beat well..alot of cars haha im using it mainly for street..maybe some track. my point is what should i go with...13B, 20B what tranny, basicaly my budget for the engine is about 4-5000. and the tranny.well id like a combo but if not probably around 2K for that..and im def. gonna need new breaks and suspension? so ..*sigh* help a noob out.haha
Old Dec 21, 2008 | 03:03 PM
simplyphp's Avatar
Here's a tip: do a search.
Old Dec 21, 2008 | 03:04 PM
RedefineRX8's Avatar
Super-impreza!
if you have 4k, you aren't even in the ballpark for a 20b.
Old Dec 21, 2008 | 03:05 PM
RWagz's Avatar
Piston-free 07.11.2007
Let me list the options within your price range:
Swap RENESIS for RENESIS
Old Dec 21, 2008 | 03:07 PM
kseer's Avatar
hmm..maybe i dont want'a rx-8..yall seem to be *********
Old Dec 21, 2008 | 03:09 PM
Kane's Avatar
Senior Member
Not real smooth and un-assuming are we? Smells Troll-y in here.
4K is about 2/3 of the price you need for a low end turbo - never mind a motor.
Super-impreza!
no, you are a troll.
A BASIC search and common sense is with any kind of major modification like this shows you are going to be getting in WAY over your head if you think 4 or 5k is enough to do a complex swap such as the 20B.
Old Dec 21, 2008 | 03:13 PM
EdwardsB's Avatar
Registered RX-8 User
if a 20b swap was that cheap, you would see a lot more 8's with it...read up more your looking in the 20k ballpark start to finish.
Old Dec 21, 2008 | 03:36 PM
05rex8's Avatar
sold the 8... :(
really shows the lack of intelligence here...after two posts you start insulting us. nice. now go do some research before you start making stupid threads.
Old Dec 21, 2008 | 03:52 PM
RWagz's Avatar
We're not attacking you. We're trying to force the facts through your thick skull.
Stop acting like the child you are.
Old Dec 21, 2008 | 03:57 PM
Kane's Avatar
Senior Member
You need a 2JZ....
Old Dec 21, 2008 | 03:58 PM
05rex8's Avatar
sold the 8... :(
hahahhahaha
Old Dec 21, 2008 | 04:03 PM
laythor's Avatar
I zoom therefore I am.
let me explain to the OP why he finds himself in the middle of flameville:
1. You don't know how to spell
2. Your grammar is equal to a retarded tree frog
3. You've read just enough to figure out that a 20b swap is something that people like
4. You have not read enough to figure out what it would cost
5. You made a post in hopes of getting lots of people to stroke your e-peen but instead found your e-peen cut off at the stump.
6. The civic forums are that way --------------------->
Old Dec 21, 2008 | 04:06 PM
Rotr8's Avatar
whines all the way home
But guys he realizes the cost,,,,
Old Dec 22, 2008 | 01:13 AM
Falken's Avatar
Drop it into 3rd
Falken enters with the benefit of the doubt again
So, you want a new engine, here's what you're looking at.
-Firstly, you need the engine. That will be 4k for a good C code longblock. 20Bs came in 4 codes, you really want a C or D code. $4000
-Secondly, you can't just use that 20B as is, you need to rebuild it. It probably has 50k+ miles on it. A good rebuild can be 2k or 1k if you do it yourself. $6000
-Thirdly, you decide if you want to keep the sequential twin turbos on the 20B itself, which you probably don't if you want more than 350whp or so. A single turbo setup done correctly will be 5k at minimum. $11,000
-Fourth, the engine must be configured for your application. That means porting, balancing, and clearencing, which is going to be 3k. $14,000
-Fifth, you need a standalone ECU, which START at 2k. $16,000
-Sixth, find a new transmission, the RX-8s will snap in two. A built T-78 runs 3k minimum and goes up from there. $19,000
-Seventh, you need someone to put the engine in the car. The steering rack has to be fucked with, firewall, axle clearence...labor alone will be 10k minimum, for someone who knows how to do it and knows what their doing. $29,000
-Eighth, someone needs to fab up custom manifolds for you, and god only knows how expensive those are. $GOD ONLY KNOWS
You get the idea. It adds up quickly. And that's the basics, I haven't even factored in the special stuff, Lightened rotors $3,000, Apex seals carbon or ceramic $1,000-$3,000, competition FD bearings $500, aftermarket eccentric shaft (<<<<important) $3,700.
The reason people are flaming you is because you said you wanted to do it for 6 grand, which says to people that you don't know what you're getting yourself into. So, we're laughing at you. A 20B swap is the most involved, complicated swap that has been performed on this car to my knowledge, it's not really something for "noobies" to be looking into.
Now, of course, if you really have a dick that ejaculates money like you say, I'm sure you can pay $GOD ONLY KNOWS. If you can, contact Defined Autoworks, they're the best in the business, bar none.
Old Dec 22, 2008 | 01:18 AM
paulmasoner's Avatar
Asshole for hire
for that kind of money your looking more like doing a turbo kit for the Renny motor, not a swap
Old Dec 22, 2008 | 02:35 AM
Easy_E1's Avatar
20b = 20k
Old Dec 22, 2008 | 02:42 AM
kersh4w's Avatar
Hit & Run Magnet
i believe one of the boricuas did it for under $8k.
im serious! afair, he said it was 7+ something, took him 3 months, and he did most of the work.
im pretty sure angel is using the stock tranny with his turbo 20b.
Old Dec 23, 2008 | 12:54 AM
nope.
he made an adapter and put a rx7 transmission in it..
Old Dec 23, 2008 | 04:32 AM
8 Maniac's Avatar
Senior Member
First off... you dont know the costs. If you're limited to about 4k for the motor, then you simply cant afford to do the swap. Either that or you have it all priced out and the only way you can make it work is if you only spend 4k on the motor... in that case, dont bother. Where did you find that engine? What condition is it in? How much will it cost to have shipped and imported? You shouldnt be "beating" cars on the street unless you mean by seeing who's car compensates more for "lacking areas". Chances are that the tranny you get wont be strong enough for what you'll want out of it... meaning you'll probably need to get it separately. You're better off getting a turbo.
The only reason I would say you should swap engines is if you have a blown motor or actually understand and can afford to do a proper swap.
BTW, we have a 13B in the car... it's just one of the variations. Depending on which 13B you're asking about, it might be better, but it might not.
You obviously do not understand what you're getting yourself into if you can't take the time to look up what results people have had doing various swaps. Come back once you've done a bit more research and have actual questions about each option.
Old Dec 23, 2008 | 02:28 PM
SlideWayz's Avatar
RX-8 = Japanese MG
Originally Posted by Kane
You need a 2JZ....
Your '2JZ' pic is PRICELESS !!!
After you get out of the Nav, you should seriously consider a career as a comedian!
Thanks!!!
Old Dec 23, 2008 | 02:30 PM
kersh4w's Avatar
Hit & Run Magnet
but you gotta have that nasss as well.
kersh4w's Avatar
Hit & Run Magnet
Lol Jedi!
Old Dec 23, 2008 | 02:32 PM
that's hilarious!
