NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
steering wheel removing too, philly
Old Dec 18, 2008 | 03:39 PM
lepichichi's Avatar
I LuV mY Rotary....
Smile steering wheel removing too, philly
does anyone has a steering wheel remover tool i can borrow???? i dont feel like paying $35 for something i'm gonna use once, thanks
Old Dec 18, 2008 | 03:49 PM
model_no15's Avatar
If your taking off your orignal steering wheel you don't need the special tool, it just slides right off
Old Dec 18, 2008 | 03:50 PM
model_no15's Avatar
I forgot to mention make sure you steering wheel isn't in the locked position
Old Dec 18, 2008 | 03:54 PM
Highway8's Avatar
Registered RX8 Nut
Umm, no. Unless something is wrong, you are going to need a steering wheel removal tool. The steering wheel is pressed on to the tapered shaft by the bolt that holds in on. I have taken mine off twice. once to replace the steering wheel and once to fix my mistake. I purchased a pulley removal set from harbour freight for about $10.
It will not want to come off at first, so you will have to turn the tool harder until you hear a laud pop. Your heart will skipa few beats because you will think you broke your car. You will then remove the tool and find everything is just fine.
Old Dec 18, 2008 | 04:37 PM
lepichichi's Avatar
I LuV mY Rotary....
^^ cool guys i'll give it a shot this weekend, thanks!
Old Dec 18, 2008 | 04:51 PM
Silver06's Avatar
Zoom Zoom....
lepichichi.
Can't really help, but did you call around to autoparts stores? Around here, several have a loan-a-tool programs where they'll loan specialized tools for free (just a deposit).
Good luck.
Old Dec 18, 2008 | 06:57 PM
model_no15's Avatar
I put a MOMO steering wheel in my car and a friend took his steering wheel off. Two different RX8 and none needed a steering wheel removing tool. Just try it and remember to disconnect your battery, and make sure the steering wheel is not in the locked posistion.
Old Dec 18, 2008 | 10:39 PM
Highway8's Avatar
Registered RX8 Nut
I dont know why your just came off. I installed a black/red mazda steering wheel and it came with the directions that explained you must use the steering wheel removal tool. Also dont hit the shaft with a hammer.
Old Dec 18, 2008 | 10:47 PM
G3tR3DDY2GR3DDY's Avatar
have removed about 6 of them. They slide of with a little force. no tools necessary. Give it a good whack in each corner then pull
Old Dec 19, 2008 | 03:32 PM
lepichichi's Avatar
I LuV mY Rotary....
hey guys i bought the tool for 12 bucks at pep boys i'll figure i might use it more than once and it might come in handy later on, thanks for the advice my new steering wheel looks awsome i will post some pics later on,
Old Dec 19, 2008 | 03:51 PM
Smoke Honda's Avatar
Mid-Boss
Trust me. You'll need it.
Make sure the wheels is as straight as possible or you'll have a really fun time adjusting it later.
Make sure you disconnect the battery and let it discharge for 30 minutes.
Be careful of the rubber band. It's there for a reason.
BTW: You can rent tools at Advance Auto and Autozone for free.
RevMeHarder
Jun 1, 2026 02:30 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
M RX 8
Aug 5, 2015 06:45 PM
