Aem Cold Air Intake, Rain Problems
Old Dec 14, 2008 | 07:00 PM
ballistc's Avatar
so it rained today for the first time after i installed my AEM cai.
and i noticed it was dripping wet...
is this okay? does the sock protect it from the rain?
Old Dec 14, 2008 | 07:05 PM
hakuna matata!
doesn't really protect it no..
you will suck up water with that design regardless just try to avoid bigger puddles..
Old Dec 14, 2008 | 08:43 PM
Jon316G's Avatar
Grasshopper
The sock will protect the filter from dirt & debris, but not water.
I know first hand that too much water inside the filter will allow water to rush into the engine while making accelerated turns.
You can remove the filter and let it air dry, but it'll take a couple days.
You can also remove the black rubber couplers connecting the straight pipes and see if water has made it up that far (it'll be noticeable).
But like alz0rz said... avoid large puddles.
Old Dec 14, 2008 | 08:48 PM
ferg's Avatar
CAI is only for racing, not everyday driving, but you can , just take care of the filter alot, and try to not drive in the rain i guess
Old Dec 14, 2008 | 08:50 PM
RyanX-8's Avatar
2004 Titanium Grey GT
yeah i just try not to drive in the rain... sometimes you cant help it tho. I dont think there is anything to worry about as long as you arent running through puddles.
Rotr8's Avatar
whines all the way home
K&N has a drycharger used for marine applications and, just find the right size, it works great I have one on my filter, they're about $20...
Old Dec 14, 2008 | 08:51 PM
Flashwing's Avatar
3-wheeler
ballistc,
I've had the same issues with rain here in Phoenix. Fortunatly we don't see much of it, but when it does rain it comes in buckets.
There's not going to be enough water to cause any engine problems and it's impossible to hydrolock the rotary to begin with. The issue is that enough water will get pulled into the intake via vaccum that the Mass Airflow sensor reads it as incoming air.
I've actually seen 360 grams/sec of MAF readout with water in my intake. It only happened above 5,000 or 6,000 RPMs. As long as you stayed in the lower power band you were ok. I found anything above those RPM's caused wheel spin anyway.
If anything, take your MAF out and clean it using electrical contact cleaner. Don't lose the gasket! It takes maybe 10 minutes to do.
Old Dec 14, 2008 | 09:38 PM
ballistc's Avatar
thanks everyone for your input!
Old Dec 18, 2008 | 07:53 AM
yokohamaboi's Avatar
Tea?
Um why dos your user say ballistic? are you with ballistic "Scion"?
Old Dec 19, 2008 | 10:26 PM
Tea?
http://www.outerwearsracing.com/index.asp
this will some what kinda protect you. so peace
Old Dec 20, 2008 | 03:20 PM
r0tor's Avatar
i'm guessing this would be a gigantic problem if it were to get wet then freeze... i think i'll pass on it
GK1707
Dec 2, 2015 10:01 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
PTQLam
Aug 16, 2015 05:40 PM
MrORAN6E
Jul 24, 2015 09:32 AM
AussieGray
Jul 16, 2015 03:58 AM
