hissing noise
Old Dec 7, 2008 | 11:32 AM
robSC's Avatar
hissing noise
My 2006 makes an intermittent hissing noise - usually after coming off the gas pedal. Seems to be worse when running the AC. Is this normal?
Old Dec 7, 2008 | 12:07 PM
DOMINION's Avatar
I don't buy Kool-Aid
Could be the sound of your Rotary or Tranny. Its norm for you to hear the Trannys wind or as you put it hiss.
Old Dec 7, 2008 | 03:05 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah we need some more info....MT or AT is it like air hissing or a humming? what year car? Location? Milegeage?
Old Dec 7, 2008 | 03:10 PM
Triperformance's Avatar
List your specs and mileage, and try to explain the area that you hear the noise. For example, front right tire, engine, shifter and so on. Specifics for noises are nice, I would know....I get customers saying the car laughs when turning and I work at a Toyota dealership (there high on pcp!) lol. We would love to help you out .
Old Dec 7, 2008 | 04:21 PM
volcomx31's Avatar
Silver Power
theres a snake in your engine bay
Old Dec 8, 2008 | 12:53 PM
robSC's Avatar
I have a 2006 MT Shinka with around 14K. The hiss will last around 2 seconds and souds like pressure dumping. Seems to come from under the passenger side dash/floor area and is more frequent when the AC is running. I live outside Charlotte and have recently lost a pet snake...
Old Dec 8, 2008 | 01:39 PM
EDZRIDE's Avatar
2005 White GT
Engine running or shut off?
Old Dec 8, 2008 | 02:08 PM
nmarz77's Avatar
Most likely it's the A/C's expansion valve. It's located in the car on the passenger side. Either it's going bad or you're getting low on refrigerant due to a slow leak.
Old Dec 8, 2008 | 04:27 PM
robSC's Avatar
I have only heard it when the car is running. I think the AC expansion valve sounds likely. I will have the dealer check it out the next time I see them. Thanks for the help!
Old Dec 8, 2008 | 08:24 PM
No problem, give them the specifics when you take it in though! Best of luck and let us know what is was!
Old Dec 8, 2008 | 08:34 PM
HWK11's Avatar
Lighting Yellow
mine makes that sound too... sometimes it even sounds like water is pouring out or something... almost like a drain..
Old Dec 9, 2008 | 08:54 AM
EDZRIDE's Avatar
2005 White GT
Check for vacumn leaks too.
Old Dec 9, 2008 | 02:55 PM
nmarz77's Avatar
Yeah yours is definitely bad. lol
Old Dec 9, 2008 | 04:06 PM
ferg's Avatar
when i first turn on the a/c and rev i can hear a hissing sound then it stops after the ac runs for a little
Old Dec 9, 2008 | 05:05 PM
HWK11's Avatar
Lighting Yellow
hmm.... i guess ill have a trip to the dealer during the break.
Old Dec 9, 2008 | 05:10 PM
tubingchamp's Avatar
What mawd bug?
It's your supercharger.. By your name it makes it seem like you have one
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
neoksk
Sep 21, 2015 12:31 PM
