Headlight Washer
Old Nov 26, 2008 | 05:02 PM
Rotary Mike's Avatar
Registered 407 Abuser
Headlight Washer
Hey,
I just noticed my headlight washers aren't popping out right now. I can hear the motor running, but no headlight washing action. I checked and the actually washers are not popping out.
Is this due to low washer fluid potentially?
Old Nov 26, 2008 | 05:14 PM
Silver06's Avatar
Zoom Zoom....
Potentially, but not likely. Although why not fill the tank?...
It is likely that there is a clog / kink in the hose, or gunk in the nozzles. Or, are the pop-outs frozen?
You can gently pull out the nozzles to see if they are stuck.
Are you sure that it is the headlight washer motor running - pull the hose off and double-hit the wiper stalk. Fluid should spray all over the place. If not, there is a relay attached to the tank as well as the second motor for the nozzles.
By the way, in the shop manual (body), there is a whole section on this starting at Pg. 126. You can find the manual here: http://foxed.ca/rx7manual/2003mazdarx8/
Old Nov 26, 2008 | 06:03 PM
qtwre's Avatar
The same thing happened to me a couple months after buying my car. I could hear them (the sound is obvious) but they weren't washing.
I don't have a fix for you, as the dealership replaced them under warranty, but I can confirm that you aren't crazy.
Old Nov 26, 2008 | 06:15 PM
Well good to know I am not crazy.....not good to know they may not be working
Old Nov 26, 2008 | 07:21 PM
So yeah,
It seems that you're washer fluid can't get too low or the head light washers stop working.
I put half a jug of washer fluid in and BAM! Washers work again.
Old Nov 26, 2008 | 07:28 PM
Silver06's Avatar
Zoom Zoom....
well done Mike!
Old Nov 26, 2008 | 07:47 PM
Thumper3322's Avatar
makes sense!
Old Nov 26, 2008 | 08:14 PM
Originally Posted by Thumper3322
makes sense!
Yeah, but it seems strange that the
Whole mechanism won't even retract without fluid. It is motor driven right, not pressure driven?
Strange.
Old Nov 26, 2008 | 08:26 PM
eug's Avatar
eug
rukia is a metaphor
I don't remember my source, but I'm pretty sure it's pressure driven. There are two motors in the canadian spec washer tanks, but you still need enough volume being pumped through to have the nozzles pop up.
Old Nov 26, 2008 | 10:11 PM
Makes sense.
I have no idea how it works, but wouldn't it make sense to have whatever is left in the tank to clean your windows instead of your lights? I would think there would be a low liquid level sensor that turns them off for this case. My two cents of reasoning.
Old Nov 26, 2008 | 10:57 PM
climacus's Avatar
I actually underfill my washer tank on purpose in the summer to prevent the headlight washer from activating. Hell even in the winter I find it to be kind of useless. They don't seem to be very good at cleaning the salt build-up off the plastic lenses.
Old Nov 27, 2008 | 06:08 AM
rotarygreg's Avatar
grass hopper
Makes sense.
the headlight washer pump still pumps when the fluid is too low, beleive me, you can hear it. it must draw from a part in the tank thats a little higher up so that it will stop using your washer fluid when you run low. it is pressure/volume actuated and the lines running from the pump to the nozzles are Fing huge, so you can imagine how much it must take to work those bad boys. and I just went through this. they stopped working one day, then the next day my low washer fluid light came on. so i topped up and its all good now.
greg
Old Nov 27, 2008 | 08:34 AM
YEah, I noticed the actual salt didn't disappear much, but last night the difference before and after I sprayed the lights (from the drivers seat) was huge. These designed for me and my excessive winter highway driving.
I always wanted these on colbalt and the f'ing huge head lights.
Old Nov 30, 2008 | 04:35 PM
Bishop's Avatar
Attack of the Black
Hey,
"headlight washers"????? Whatchoo tawkin bawt Willis??? Does my 8 have headlight washers??
Old Nov 30, 2008 | 04:45 PM
prospectjtaz's Avatar
If your 8 is CDN it does, I think their stupid. They should have been made flush mounted to the bumper like beamers do it. Not sticking out. Plus once you go new bumper, they become obsolete, no way in hell are your gonna start cutting into your new mspeed bumper or other bumper just so you can maintain the washers.
useless, they should have given us all the TPMS sensors.
Old Nov 30, 2008 | 04:50 PM
Bishop's Avatar
Attack of the Black
And how exactly do I activate them?
Old Nov 30, 2008 | 04:56 PM
Daemos's Avatar
I have found depending on the fluid you use it can be better or worse at cleaning.
Old Nov 30, 2008 | 05:01 PM
doulbe tap the stalk for it if u want to manually engage them
Old Nov 30, 2008 | 05:05 PM
rotarygreg's Avatar
grass hopper
if you have them (made obvious by the match like thing on the front bumper just infront of each headlight) they spray on their own when the headlights are on and you use your windshield washer spray. also, i think double flicking the washer spray will make them work too as normally, they only spray once in a drive with the windshield spray.
oh and jay, the TPMS is useless too. in my experience with these TPMS setups both at toyota and now mazda, they are more of a headache then they are worth. its not like its hard to check your tire pressure on occassion and when the system has a problem, the sensors arent cheap. plus all winter you have to deal with the bright light on your dash unless you fork over the extra money for new sensors in your winter wheels.
Greg
If I had them i would aim them the other way so i spray at people,
like that crazy R/C car I had as a kid, where you can hit the button on the remote, out pops the hidden viper and sprays water at you.
Old Nov 30, 2008 | 05:07 PM
You dont need sensors in your winter tires, it gets into the whole, I NEED WINTER PERFORMANCE TIRES, cause I wanna drive past 160 KM/H. The tpms sensors are really desgined sturdy, barely do I see posts about them failing on the forum. Only thing I could ask for is a digital gauge readout of the psi, but thats just for novelty sake.
Solution to bright light, --> black tape
Old Nov 30, 2008 | 05:34 PM
I would rather have the TPMS over the headlight washers. If you really need the light washers, you aren't cleaning your car enough anyhow . With the TPMS never worry about tire pressure and when it got cold out sure enough it came on and one was low
Old Nov 30, 2008 | 06:20 PM
Thief's Avatar
Reppin Lightning Yellow
I prefer to have neither :P
Old Nov 30, 2008 | 06:29 PM
rotarygreg's Avatar
grass hopper
black tape? im sorry, but i stopped applying tape to cover up lights on my dash when i stopped driving suzuki swifts. Like i said, ive seen some nightmares that had to do with TPMS. I would rather have neither (washers or tpms) but because its like one or the other (american car or canadian car) im glad i have the washers. if any part of it stops functioning, i likely wont notice, and if i do, wont care.
and marc, its not about keeping your car clean, sometimes on a long drive in really shitty winter weather your car can get so dirty, you dont want to stop and wash the car twice before you get to your destination.
those are shots of my old lancer after a 50km drive last winter on a perticularily bad day. The car was washed the day before.
Greg
