tranny fluid leak
Old Nov 25, 2008 | 09:30 PM
i.s.d_se3p's Avatar
insidious
tranny fluid leak
what up people! well im almost possitive its a tranny fluid leak but not sure! ive search the forum and didnt really find any usefull info. it doesnt leak much, only wen i let the car sit over night! buts its been a daily thing for the last week and a half! ive looked all over the tranny and found a few potential leak spots but just hopeing you guys could shine some light on the situation!
Old Nov 25, 2008 | 09:44 PM
Rear seal, front seal, neutral switch and transmission body...most likely in that order
Old Nov 25, 2008 | 10:28 PM
when was the last time u change ur tranny fluid ? it could be worn gasket.
if not then, follow the order that dannobre has said.
Its pretty rare that the front seal will leak. ONLY if u've ever touched it.
Old Nov 26, 2008 | 09:27 PM
i.s.d_se3p's Avatar
insidious
thanks for the info.... im still searching for that leak tho! i havent looked but my gears are starting to get rough between shifts...i guess i better get on it huh!
Old Nov 28, 2008 | 09:01 AM
04RX8man's Avatar
Rotary Powered Countryboy
well you need to make sure that there is fluid in there if it is just aleak that does not need to b torn apart to fix you will kill ur tranny by not having fluid in it.....
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
XianUnix
Sep 29, 2015 03:48 PM
DG07
Sep 28, 2015 10:58 AM
