Front end clack sound.
Old Nov 23, 2008 | 09:46 PM
Grimacus's Avatar
I have an issue, found no info on it, so I am just going to ask before my car goes into the dealer to get looked at. My problem is when I back up and then move forward and hit the brakes I get this loud clack sound coming from the front of the car. My car was just serviced a couple weeks ago and had both motor mounts replaced due to the car engine shaking alot.
Old Nov 23, 2008 | 10:09 PM
volcomx31's Avatar
Silver Power
i get a snap/clunk noise when i reverse only..i wonder what it is
Old Nov 24, 2008 | 09:01 AM
EDZRIDE's Avatar
2005 White GT
Try this: http://www.finishlineperformance.com...5-08-1948a.pdf Worked for me!
Old Nov 24, 2008 | 09:30 AM
Yep, Control link is a good place to start.
Old Nov 24, 2008 | 09:33 AM
I took my control link out 3 weeks ago. Its completely apart from each other. just like what it looks like in the TSB.
Replaced with Autoexe part. Couldn't be happier
Old Nov 24, 2008 | 04:40 PM
volcomx31's Avatar
Silver Power
i should go to the dealer and have them fix it..
Old Nov 26, 2008 | 01:02 AM
Grimacus's Avatar
My car is still at the dealership, they told me its just normal wear and tear and basically its a spring on the brake caliper that doesnt hold as tight as new, im having a manager look into it now, to me this just sound normal.
Old Nov 26, 2008 | 04:35 PM
volcomx31's Avatar
Silver Power
i also noticed that when i drive my car, the front suspension squeaks often..any thoughts?
Old Nov 26, 2008 | 06:50 PM
Grimacus's Avatar
Well got my car back, they basically did nothing, told me my brake pads dont have the updated pads, not covered under warranty, and told me its the brake pads shifting and causing the click. Only thing they did was supposedly lubed the slave rod, though I told them i'm getting a squeaking sound when I push my clutch pedal in, you can hear it coming from the pedal area, dont know why they looked at the slave rod. I gave them a few bulletins to look over, not sure if they did. I guess I will have to take it to another dealership here in Fort Worth, Texas.
Old Nov 28, 2008 | 09:04 AM
04RX8man's Avatar
Rotary Powered Countryboy
if you're squeaking clutch pedal is right at the pedal you better b careful many ppl have BROKEN their clutch pedal when it started to squeak....
Old Dec 1, 2008 | 04:12 PM
Grimacus's Avatar
Doesnt happen all the time, when I was at the dealership of course it wasnt doing it, but it happens lets say when you are depressing the clutch pedal and moving it up, as it nears the top is makes a rubberish sounding squeak, same thing is you are pushing the clutch pedal in, seems to start as you push it.
Azki23
Jun 27, 2018 03:48 PM
TJSiegrist
Sep 10, 2015 09:29 AM
just1jack
Sep 9, 2015 04:45 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
rxwilly8
Sep 2, 2015 02:42 PM
