flooded
Old Nov 23, 2008 | 09:07 PM
tingling's Avatar
flooded
damn my car flooded for the second time in 1 month >.<
it was really wierd i was parked on the road and i turned it on ok i was going to go up my driveway as soon as i hit the slope rpms dropped and it stalledd..
i tried the de-flood procedure but it didn't work.. any advice?
Old Nov 23, 2008 | 09:28 PM
Thief's Avatar
Reppin Lightning Yellow
If the deflood procedure doesn't work, you have two options.
1) Push start (hard on clutch)
2) Get it towed to the dealership (hard on wallet)
Old Nov 23, 2008 | 09:31 PM
tingling's Avatar
option 2 cost me 900 last month sigh....
Old Nov 23, 2008 | 10:05 PM
Thumper3322's Avatar
option 1!!
Old Nov 23, 2008 | 10:13 PM
tingling's Avatar
how can i do a push start i have never done one befor?
Old Nov 23, 2008 | 10:29 PM
have someone push your car down hill get up some good speed, have your key set to on, push in the clutch and have it in first gear before pushing, when it is going at a good speed, let the clutch out all the way really fast, and throw it back in as fast so it doesn't stall. Engine should be running then.
Old Nov 23, 2008 | 10:39 PM
tingling's Avatar
thanks... i'll give it a shot in the morning... its really freaking frustrating having this happen 2 times in less then 30 days..
Old Nov 23, 2008 | 10:41 PM
dude what are you doing to make it flood so much? turning it off when it's cold or something?
Old Nov 24, 2008 | 10:25 AM
Rotary Mike's Avatar
Registered 407 Abuser
Yeah, I don't get this flooding issue.
I turn off/start my car all the time when it is cold. Sometimes it is running for less them 1 minute (just rolling the car out of the driveway. I always do the 3000-4000RPM rev before shut down and my car always fires back up later when I start it. Even with my weak 2004 Starter.
Old Nov 24, 2008 | 12:29 PM
tingling's Avatar
i dont know what going on i dont usually shut off my engine cold...but i moved my car yesterday morning for my dad spent about 10 to 15 sec reving it and then shut it off.. turned it on after to move it had a wierd rumble at start up tried to drive up my driveway and it stalled couldn't turn it back on
Old Nov 24, 2008 | 12:45 PM
**** man!! Mike is lucky I never turn off my car cold. I have read as long as your temp gauge is over the first 2 big lines and rev it up then you can turn it off ok. No way do I chance that, even if it is just hit warm up temp and I have to turn it off, I rev it up.
Get her started up, don't hit any gas or do anything, just let her sit idle for 5-10 min she should clean herself out.
Old Nov 24, 2008 | 01:36 PM
**** man, 5-10 minutes? I let it rev up for only 30 seconds usually.....and I don't pre-mix.....and I use 5-W20......and I don't hit my reline everyday (most days)......
Old Nov 24, 2008 | 02:07 PM
01Racing's Avatar
We have a flooded RX8 in the shop now, dark green, anyone from this site??
Old Nov 24, 2008 | 02:17 PM
No not on a normal day! I'm telling him once he gets it started to just let it idle until it works his **** out. I let mine idle normally when cold between 2-4 min, depends if I'm smokin or not and how long it has been sitting. Same oil here and I do my best to hit redline every day. U will only notice problems later in life of your car.
Old Nov 24, 2008 | 02:25 PM
tubingchamp's Avatar
What mawd bug?
I've never shut my car off when it's cold.
I have an 07, though, so I should be fine with it, but it's not a risk I'm willing to take.
I redline it multiple times a day.
"A redline a day will keep the stealership away!"
Old Nov 24, 2008 | 02:35 PM
Thief's Avatar
OMG IT'S A NORDIC GREEN. Pics please.
Old Nov 24, 2008 | 02:47 PM
Hopefully early next week you'll have a winning blue in the shop getting a leaking oil pan fixed
Old Nov 24, 2008 | 06:36 PM
climacus's Avatar
When I was looking for my car I test drove one that was imported from the US. That car was in crappy shape, but pretty cool looking. I bet you it get mistaken for a Jag or Aston Martin all the time.
Old Nov 24, 2008 | 06:45 PM
tingling's Avatar
well i fixed it...
i bought new spark plugs $55 each... i took out the old spark plugs and i pulled the fuel relay out... tried turning it on with that spark plugs still out some oil came out of the holes i cleaned out the holes did it again and nothing came out this time.. put the new spark plugs in and tried starting with fuel relay out still.. then i put it back in and tried still didn't start.. then i alternated with fuel relay in and out a few times and it started...
hope that will help if it happens to anyone else...but i really hope it doesn't..
Old Nov 24, 2008 | 07:15 PM
$55 a plug where did you buy them from? That seems a bit pricey. Good to hear she is going again!
Old Nov 24, 2008 | 07:56 PM
rotarygreg's Avatar
grass hopper
55/plug would be about dealer list price IIRC.
as for bumpstarting the car like marc mentioned....its not coincidered good practice to bump start a car in first gear. you should be able to get it up to speed enough to use second gear. first gear is very violent unless you really know what you are doing. i dont recomend it for a first time bump starter. Ive had sticky situations with my suzuki swift GTi where i had no choice but to bump start the car in reverse. that was an experience. lol.
Greg
Old Nov 24, 2008 | 08:03 PM
PeteInLongBeach's Avatar
Once the engine is flooded, does it do any harm to the apex seals to push start it? Isn't the lubrication compromised by the excess fuel?
Old Nov 24, 2008 | 08:10 PM
rotarygreg's Avatar
grass hopper
and cranking the engine over with the starter differs how? the fact is you need to get the engine started. im sure flooding it isnt good for the engines life for this reason, but the apex seals aren't doing anyone any good if the motors running so...priorities, i guess.
Greg
Old Nov 24, 2008 | 11:49 PM
Bishop's Avatar
Attack of the Black
I saw what I can only imagine is a Nordic Green today on the 427 northbound to the airport. Definitely a colour that only looks good when completely waxed up. Al, you getting a lot of flooders in lately? by the way, had her stutter just a little the other day. Think I'll be getting new coils after Christmas.
Old Nov 28, 2008 | 09:31 PM
rx8khan's Avatar
eazyryder
i dont thinl u should do a push start in first gear especially with the rx8 do it in second u get more compression....oh make sure when the car bucks and start press the clutch and lots of gass floor it or it will stall
