How do you remove the front seats? (GT Leather)
Old Nov 22, 2008 | 10:25 PM
ILoveFI's Avatar
I just got some sparco seats for cheap and was wondering how the hell do I remove the front seats? Is there something I have to do so the airbags in them doesnt go off, etc? Also is there a DIY that shows you how to remove the seats since I've never done this before?
Old Nov 22, 2008 | 10:28 PM
Undo the 4 bolts...wiring harness under the seats...lift out
If you are worried about the airbags disconnect the neg battery terminal......it isn't really an issue when the key is off...but if you must
The problem you will have is the seat brackets you need to fit the Sparco seats. Unless you are short...5"4 or so...most of the brackets won't let you sit in the seat. Especially with a helmet
Old Nov 22, 2008 | 10:34 PM
chickenwafer's Avatar
Nope
it's pretty easy. Just remove the 2 bolts and 2 nuts. They have a lot of torque so use a breaker bar.
Then there are wiring harnesses to disconnect, airbag harness is yellow.
Old Nov 22, 2008 | 10:40 PM
G3tR3DDY2GR3DDY's Avatar
there are four bolts for drivers, three for passenger and one nut, two wiring harness clips for each, and you can get it without a breaker bar :P
bmarrs's Avatar
Just got done today replacing my cloth seats with leather, and it literally took me less than 1 hour to do this... 4 bolts and unhook the wires under the seat and thats it... Yes they are torked!!!!
Old Nov 22, 2008 | 10:44 PM
Nope
Mine were torqued pretty hardcore. I had to use the pipe on my floor jack to loosen them. It's kind a bolt you want tight
Old Nov 22, 2008 | 10:45 PM
Back to the gym for you grasshopper
Old Nov 22, 2008 | 11:24 PM
ILoveFI's Avatar
I'm 6'0... Could I just bolt them to the floor? I've autoxed before with my seat all the way up and pretty high before...
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
jlm2664
SE For Sale/Wanted
Mar 9, 2016 11:50 AM
AussieGray
Jul 16, 2015 03:58 AM
