RX-8 Metra Kit and Heater not working
Old Nov 22, 2008 | 04:17 PM
tbui2007's Avatar
hi,
i'm having a problem with the heater after i installed the metra kit into my 04 rx-8. The AC seem to be working but i can't adjust anything else. I'm just wondering if anyone has ever experience with this problem? What can i do to make it to work?
Thanks !
Old Nov 22, 2008 | 04:55 PM
rollerbldes's Avatar
Yes please read
https://www.rx8club.com/series-i-interior-audio-electronics-24/metra-kit-out-157780/
Start from around page 15 or 18.
Old Nov 22, 2008 | 10:06 PM
tbui2007's Avatar
i read this post many times before i purchase the kit ! It doesn't say much about the the heater. I have tried to unplug and replug like 3 times and now the heater and a/c works but still cannot adjust anything else. A/c still on when i switch to heater. Can anyone explain this?
Old Nov 22, 2008 | 11:12 PM
Recheck your connections. It's possible you reversed the fan and temp dials. Or maybe you just have a bad unit. Contact metra.
Old Nov 23, 2008 | 06:00 PM
tbui2007's Avatar
thanks. i think i got the right connection. i'm give them a call 2morrow.
Old Nov 24, 2008 | 06:52 AM
firebirdude's Avatar
User and Abuser
I've been telling you guys all those "Axxess" boxes made by Metra are complete crap. Had another faulty GMOS-04 box on Saturday.
Old Jan 9, 2009 | 11:44 AM
KABRERASRX8's Avatar
new user here, ive looked around and couldnt find anything to compare with, but heres my issue, i have a 2004 rx8 and had a metra double din installed with a pioneer fh800bt head unit, everything works fine except i dont have cold air blowing. The techs installed the original head unit back in and it works fine, they also used up 4 modules that comes with the kit and still no cold air. does anyone have any comments, oh and the wires are all correct. i also tried to call metra about it but it seems the engineers would now something but they are not local! help please, im about to ditch the ride if it cant work.
Old Jan 9, 2009 | 02:45 PM
nuke0907's Avatar
Never Blend In
is the axxess box flashed with the latest updates? its up to 1.4 now which should fix some of the earlier reported bugs.
i would think the issue might be the soldering points on the AC module but you said it works after they installed it back to stock.
Old Jan 10, 2009 | 03:56 AM
ac will not work with metras kit
it has been flashed but the updates are to fix the twitching on the clock display of the rx8, so far ive found out that an 07 rx8 has the same issue except that car blows only cold air. thanks for the help
Old Jan 10, 2009 | 05:25 AM
Toxic Gecko's Avatar
Version 1.1 was supposed to have fixed the display freezing issue. The glitching issues were fixed with firmware upgrade version 1.2 or 1.3, but they were never publicly released. Version 1.4 is the "final" release and has fixed all known bugs thus far. Are you doing the firmware updates yourself or are you having a shop do them for you? If you are having a shop do them, make sure they have the most up to date release. I did my own from my laptop, but the shop I went to to borrow an update cable from checked their system against mine and after a few calls to Metra they were told they had to uninstall and reinstall the program before the changes took effect. I would check into that first. Make sure you have firmware version 1.4.
Then read this thread here. I had the same problem with mine. Everything worked with the factory unit, I installed the Metra kit and other then the early Metra bugs I had, the heat was still a problem. As soon as I did the DIY heat control fix from the other thread, everything has been perfect with the HVAC.
By the way, as stated above, all of this information is already in the "main" Metra kit thread, here.
Old Jan 10, 2009 | 12:15 PM
tbui2007's Avatar
i return my and got a new one..i works fine now...there is a problem with the axes box.
Old Jan 10, 2009 | 05:48 PM
Blackout04RX's Avatar
Need for Speed Satisfied
all these issues scare a guy away from buying this kit. Stocky is gonna stay till these posts stop coming up
Old Dec 27, 2012 | 07:25 PM
alan49121's Avatar
metra harness pic request
can any of you guys post a pic of the plug on the ither end of the orange plug so i can see where the wires go mine does not have the plug and im just looking to harwire it
Jesus Martinez
44
May 6, 2025 08:09 AM
MolecularConcept
Aug 5, 2015 04:43 PM
mazdaverx7
Jul 21, 2015 07:31 PM
AussieGray
Jul 16, 2015 03:58 AM
04MazdaMan
Jul 15, 2015 08:23 PM
