New installed PC680 odyssey batter!
Old Nov 11, 2008 | 02:04 AM
G3tR3DDY2GR3DDY's Avatar
Here are some pics of my newly installed PC680 Drycell odyssey battery. This thing weighs 14 lbs and is TINY, with more than OEM standards. There is SO much more room in the engine bay without that big *** battery box. Im gonna make a shield for the radiator fans soon.
let me know what you think!
Before:
Wires ran:
Mock up:
Final:
Old Nov 11, 2008 | 02:41 AM
nuke0907's Avatar
Never Blend In
looks good. lots of room. time to make that heat shield for the radiator fan.
Old Nov 11, 2008 | 02:49 AM
dshiznit1489's Avatar
Formerly Polak Graphics
nice.
Old Nov 11, 2008 | 05:40 AM
good job bro
Old Nov 11, 2008 | 05:57 AM
altspace's Avatar
Eccentric Shafting
Eh, who needs washer fluid right? Looks great. In for better full shot pics during daytime.
Old Nov 11, 2008 | 06:12 AM
whoneedspistons's Avatar
hmm looks strangely familiar... dont worry about giving me any props
Old Nov 11, 2008 | 11:21 AM
yea i guess this guy helped a little :P his car is where i saw the setup, his looks a little nicer
not me.. dont drive in the rain or weather and it stays in the garage. Washer fluid is useless... notice the first pic that was just turned into a catch can mount :P
Old Nov 11, 2008 | 11:25 AM
lepichichi's Avatar
I LuV mY Rotary....
looks good
Old Nov 11, 2008 | 11:28 AM
Better charge it lots if it gets cold......
Old Nov 11, 2008 | 11:32 AM
alfy28's Avatar
very nice
Old Nov 11, 2008 | 11:42 AM
StealthTL's Avatar
Metatron
Does that holder come with the battery?
S
Old Nov 11, 2008 | 11:43 AM
lol.. it looks good man really i was just bustin on you
TopGear8's Avatar
mkuhnracing.com
Cool cool.
Old Nov 11, 2008 | 11:51 AM
if its cold, its in the garage
S
no unfortunately it doesnt come with terminals or the casing, the case was like 25 off ebay for a "dyna pack" battery. and the terminals are actually brass L brackets that i bent at an angle to make the cable look clean and fit under the case.
Thanks for the props!
Old Nov 11, 2008 | 12:08 PM
looks good man... there's a lot of room under the hood now!!
Old Nov 11, 2008 | 05:42 PM
Sifu's Avatar
Opulence
Looks good man.
Nice engine bay
Old Nov 12, 2008 | 12:51 PM
altspace's Avatar
Eccentric Shafting
I've been meaning to try some odyssey batter. (hehe)
Old Nov 12, 2008 | 12:59 PM
ya well it makes the best damn pancakes you could imagine i cant change it...
Old Nov 12, 2008 | 01:02 PM
Spin9k's Avatar
Momentum Keeps Me Going
What holds the battery bracket to the car? I don't see any bolts going into the firewall in your pic. Nice braket thou...
Old Nov 12, 2008 | 01:21 PM
cfree's Avatar
I ran one for a while, liked the space but didnt seem to hold a charge as well or as long. Only had it for a couple weeks now its sitting in my garage.
Old Nov 12, 2008 | 01:30 PM
Yea i have to make some spacers behind the insulation because the firewall is not straight.. its not mounted yet just wedged but its not going anywhere.
Only thing ive noticed so far running it is that is the car idles a little lower. Maybe not a good enough ground? anyone?
Old Jul 23, 2009 | 10:08 PM
nuke0907's Avatar
Never Blend In
you have any ideas how to mount it where the old battery tray is, closer and lower to the ECU box?
Old Jul 23, 2009 | 10:50 PM
imput1234's Avatar
I ♥ Drifting!!!
dope, where did u relocate the wiper fluid too?
Old Jul 23, 2009 | 11:03 PM
battery is bad from the alternator so i gotta get a new one, will be putting it here and then seeing whats possible.
read above posts
Old Jul 24, 2009 | 07:02 AM
Spin9k's Avatar
One easier and possible better solution than removing the box entirely is to just put the PC680 back in the same box thereby being able to use the oem short cables, same cooling function the box gives (with cover on). For the small PC680 you need to raise it up to be able to attach the battery cables correctly so a simple piece of wood underneath did the trick. Also the oem battery clamp is made for a wide battery so I juryrigged a rubber one I bought at Autozone with a metal brace piece so as to hold the battery firmly.
Something else shown is a battery heat shield of hi-temp material like used for shielding from exhaust heat to try to keep heat soak to a minimum. The idea came from this commercial one shown below which was a bag type, I simple custom fit mine for added shielding.
BTW I used to have the PC680 where the washer fluid was, but really didn't see the point of the extra cables & box when this way lightens the battery area what like 20 lbs anyway.
