Why does the little light in the trunk draw so much power?
Old Nov 9, 2008 | 06:12 PM
Marc_H's Avatar
I don't really have a question, I'm just venting.
I went out of town for three days last week. Sometimes when I take the remote key out of the ignition, I hit the trunk release button by mistake. Prior to this time, I've always heard the trunk lid open up and I close it before leaving the car.
But not this time.
So I come back from my trip and find the battery completely dead.
I jumped it OK, but it doesn't make sense to me that the tiny little light in the trunk can draw so much power that it completely drains the battery in only three days.
To avoid this from happening again, I took the bulb out. It was mostly useless anyway, since I have a spare tire kit.
Old Nov 10, 2008 | 09:54 AM
firebirdude's Avatar
User and Abuser
I've never had the battery die, but I have popped the trunk accidentally without noticing 3 or 4 times. I now disable the pop with the button in the glove box. Must use the key now.
Also, prior to me going to key only.... you can monitor the parking light flash when you lock the doors. If they flash, you're good. If the doors lock but the lights do not flash, the trunk is popped. I always watch for the flash.
Old Nov 17, 2008 | 04:35 AM
krijpipudht's Avatar
Hi guys! My name is Tony.
From: San Francisco Bay Area 94542, USA. Earth. Solar System. Milky Way
I have LED in the trunk, never have this problem.
Also tower 25-LED is much brighter so it is still useful even there is spare tire kit.
However, I took spare tire out after a while. Waste of gas and space....
Old Nov 17, 2008 | 04:45 AM
StealthTL's Avatar
Metatron
A 25 LED will leave the battery just as dead after three days.....
There is a neat DIY that runs an led off the same power, mounted in the center of the plastic rear shelf, and shines in your rear view mirror when the trunk is popped.
S
Old Nov 21, 2008 | 02:53 PM
wonderful-life's Avatar
I have exactly the same problem. I left my car for 2 or 3 days at most then the battery was completly flat. Not even enough battery left to receive signals from my fob. I notice the trunk was poped. I thought I hited the trunk bottom whitout knowing it. It happent again! And I'm 100% sure I did make sure it was closed before I left the car. How can my trunk just pop up like that? Is it an electrical issue here? Don't want to take out my battery and recharge it and place it back, take soo much time.
Old Nov 21, 2008 | 02:59 PM
User and Abuser
You're accidentally pressing the button on your keyfob. I had this happen 3-4 times. Disabled it by pressing the button in the glove box. Hasn't happened once in over a year.
Old Nov 21, 2008 | 03:15 PM
There is no way, even if I accidentally pressed the button, it wouldnt pop up.
I have to press down my trunk button and hold it for 1 sec to open the trunk.
It would never happen if I just press it.
Old Nov 22, 2008 | 02:49 AM
you can disable the trunk lock in the glove box.
problem solved.. that wack stuff is in the owner manual..
btw, 5 years almost 100k miles. i have not had the hit the trunk release by accident..
how is that?
Old Nov 22, 2008 | 07:41 AM
User and Abuser
Well what can I say? Once you disable it, the trunk magically never pops open again. Problem solved no matter what the cause.
Old Nov 22, 2008 | 12:54 PM
But I really don't understand, why does it automatic pop up the trunk? Im sure i'm not pressing the trunk release.
Warrior777
Jun 24, 2019 04:47 PM
coolcars44
Nov 29, 2017 05:45 PM
Rajareits
Aug 27, 2015 08:21 AM
