After 23,000miles my Greddy turbo dies
Old Oct 31, 2008 | 11:34 PM
turborx8's Avatar
Boost 4 Life
It was fun while it lasted. I knew these cheap turbos never last very long.
Any idea what a rebuild costs? I am thinking it will cost me more in labour than actual parts. It's quite the job to get that turbo out of there.
Old Nov 1, 2008 | 12:06 AM
RedefineRX8's Avatar
Super-impreza!
what exactly happened???
sorry to hear...
Old Nov 1, 2008 | 12:11 AM
ask mm, mysql and crh for more info.
pm any or all of them
Old Nov 1, 2008 | 12:15 AM
turborx8's Avatar
Boost 4 Life
sorry to hear...
I am buring loads of oil and I get a big white cloud of smoke on startup and in boost.
Apparently it's normal for these turbos to die in such a short period of time.
Old Nov 1, 2008 | 12:32 AM
Brettus's Avatar
Boosted Kiwi
23000 actually sounds OK in comparison to most - what is your secret ?
Old Nov 1, 2008 | 01:44 AM
chickenwafer's Avatar
Nope
Just to rebuild the turbo is around $400-$500 bucks for parts and labor depending on the shop and if you have any serious damage.
For a shop to remove the turbo from your car and then reinstall it, you're probably looking at 3-4 hrs of labor unless it's a shop that has wrenched on this kit before. Unless you know the tricks, it can take a long time.
Old Nov 1, 2008 | 02:29 AM
turborx8's Avatar
Boost 4 Life
Thanks for the quote.
Nobody anywhere near me has ever touched a turbo 8 so I will need to double that labour figure.
Old Nov 1, 2008 | 02:30 AM
turborx8's Avatar
Boost 4 Life
I dont have the oil restriction mod installed.
Old Nov 1, 2008 | 03:29 AM
Brettus's Avatar
Boosted Kiwi
are you saying the oil restriction causes premature failure ?
Old Nov 1, 2008 | 04:14 AM
turborx8's Avatar
Boost 4 Life
Nope.
I just figured it might be important to mention it.
Old Nov 1, 2008 | 08:59 AM
mysql's Avatar
Doppelgänger
my greddy turbo was rebuilt twice.
original had no restrictor, it died within a year.
after that it had the proper restrictor, it also died after a year.
then I sold it after buying the 3071R upgrade.
The smart thing to do is not mess with the greddy turbo at all. Replace it from the start so that you have $500 or so from it's sale to apply to the 3071R. Now you can enjoy massive torque gains and 400 hp without worrying about taking out the manifold and turbo every year - or at best, every other year.
Old Nov 1, 2008 | 12:46 PM
turborx8's Avatar
Boost 4 Life
My dead turbo is worth $500? lol
Old Nov 1, 2008 | 12:50 PM
mysql's Avatar
Doppelgänger
read again. if you sold it when it was new.
if you have it rebuilt, you can get 300, maybe more.
Old Nov 1, 2008 | 12:57 PM
wouldn't rebuilding it cost more then the $300 he'd get for it?
soorry to hear about the turbo, time for the upgraded Garett
Old Nov 1, 2008 | 12:58 PM
turborx8's Avatar
Boost 4 Life
Not worth it.
chickenwafer says "Just to rebuild the turbo is around $400-$500 bucks for parts and labor"
Old Nov 1, 2008 | 01:03 PM
mysql's Avatar
Doppelgänger
if you can disassemble the turbo yourself and replace the bearings, it can cost you a lot less (in the range of $20 for parts). But you need to know how to reassemble it properly, otherwise it costs to rebalance it.
Jeff rebuilt mine. Is there anything he can't do?
Old Nov 1, 2008 | 01:57 PM
Brettus's Avatar
Boosted Kiwi
Learn to drive with the extra power of the Greddy then upgrade when it dies - even smarter
Old Nov 1, 2008 | 02:05 PM
mysql's Avatar
Doppelgänger
nah. just turn down the boost control if it's too much for you
Old Nov 1, 2008 | 02:18 PM
Brettus's Avatar
Boosted Kiwi
that would be like saying to a **** addict - only watch this movie till they take their clothes off then turn it off - LOL
Old Nov 1, 2008 | 07:37 PM
arghx7's Avatar
20k miles out of an aftermarket turbo isn't all that bad. What did you expect? usually it is only OEM turbos in OEM applications (with all the OEM plumbing for it etc) that last 80-100k. and remember that when you turbo a car that wasn't turbo from the factory, you are probably going to beat the **** out of it to get your money's worth.
Old Nov 1, 2008 | 07:40 PM
Derex'8's Avatar
ReDuX
I wonder if the problem is w/the location of the turbo in this kit...doesn't look like it allows for gravity to play its role so oil can fully drain out the turbo?
Old Nov 1, 2008 | 07:54 PM
mysql's Avatar
Doppelgänger
Any manifold mounted turbo will have the same location and same drain. I didn't have any issue with the 3071R but then again, with that turbo the oil is for lubrication only, cooling is done by coolant. Nice thing about coolant for cooling is if you shut off the car while it's still hot, the coolant heats up and rises, so cool coolant comes in from underneath and it naturally circulates without any additional hardware.
Old Nov 4, 2008 | 04:45 PM
SlideWayz's Avatar
RX-8 = Japanese MG
You're lucky that you've gotten 23K out of your turbocharged ENGINE !!!
Old Nov 4, 2008 | 08:45 PM
c41250n's Avatar
does any body knows where have MM been?
Old Nov 4, 2008 | 08:55 PM
http://www.majesticturbo.com/
Hey man, I know these guys and they have rebuilt a couple of turbos for me. Call them for a quote or buy an HKS or Turbonetics snail and you will be happy. I learned to stay away from Greddy back when I bought my first Greddy kit. And a Turbo should last a lot longer than 23,000 miles for a street car.
