heater help
Check and see if the actuator valves are working on the air transfer system..you will need to look up under the dash on the drivers side..and likely remove the Right knee moldings around the head unit to see it....
Check out this thread: https://www.rx8club.com/series-i-do-yourself-forum-73/diy-no-heat-repair-heater-control-158200/
Apparently it's a common issue....
bean438
Canada Forum
17
Sep 25, 2004 03:30 PM
