Raspy Sound and Coils
Old Oct 30, 2008 | 12:13 PM
RX8SaxMan's Avatar
So earlier this year my RX-8 starting running rough with a raspy sound after it was nice and warm. On couple of occasions I got the misfire CEL. I figured I'll replace the coils, so I bought 4 new ones and stuck them in.
The car definitely felt better afterwards, but after long (1.5 hr+) drives, the raspy sound still comes back, and I've had the misfire light once more. Just for fun I took it to the dealer to get their opinion, and they're telling me my trailing coils are bad. They're only 5 months old, and the problem only happens after long drives. Could the dealer be right, or does anyone have a suggestion of what else it could be?
My car has about 80,000 miles. I just bought a new fuel pump, but haven't had a chance to install it yet. Any chance it will fix the problem? Thanks!
Old Oct 30, 2008 | 01:14 PM
invasion08's Avatar
It could be the trailing spark plugs because if the coils were not working up to par your plugs could go bad fast. Take the trailing plugs out and see what they look like. If you need new plugs go to www.autopartswarehouse.com you can get all 4 shipped for 85 dollars.
Old Oct 31, 2008 | 02:43 AM
fuel pump. i have been through this before.. btw, have you been premixing?
Old Oct 31, 2008 | 11:04 AM
RX8SaxMan's Avatar
Cool. Hopefully I'll be able to find time this weekend to swap the pump. I have never premixed.
Old Oct 31, 2008 | 11:59 AM
elysium19's Avatar
I know there was at least chatter (substantiated or not) about premixing and the fuel filter. I don't really know where that's located......if you buy a new pump, is the filter new as well, part of that unit?
Old Oct 31, 2008 | 12:16 PM
RX8SaxMan's Avatar
Yes, the pump and filter are a combined unit.
Old Oct 31, 2008 | 04:19 PM
what flash are you on? it could also be drying apex seals depending on the flash..
Old Oct 31, 2008 | 04:54 PM
RX8SaxMan's Avatar
I just had the MSP16 recall/flash done a couple months ago. That was the first thing I tried since it was free. It helped my low power problem when the outside temps were 100+, but the raspy sound was still there on long drives.
Old Oct 31, 2008 | 06:47 PM
ok,,
at least this is interesting.. i am going to make some guesses..
04 auto? you got it used? and this is the first flash it has?
Old Oct 31, 2008 | 06:59 PM
RX8SaxMan's Avatar
'05 6MT, bought it brand new, and always kept up with the flashes :-P
Old Oct 31, 2008 | 07:08 PM
ok,
this is fun..
raspy and in starts to sound more deep? the 1.5 hour mark is my clue.. that is when my fuel pump would get warm and shut down.. but after 5 min it would start right up and drive fine..
how old are the plugs and wires? do you have some friends you can swap stuff out with?
Old Oct 31, 2008 | 07:26 PM
RX8SaxMan's Avatar
Yeah that sounds exactly like what is happening. After the engine has cooled off it drives great. I changed the wires with the coils (5 months ago), and the plugs are about a year old. Unfortunately my only friend with an RX-8 lives 2 states away, so swapping parts isn't gonna happen. I'm hoping replacing the fuel pump will take care of it...
Old Nov 1, 2008 | 12:40 PM
before you replace the fuel pump send me a pm.. i would like you to try something..
Old Nov 3, 2008 | 04:25 PM
Faxie's Avatar
This sounds a bit familiar... i just ordered new coils.... same kind of sound (i think)
Could it be that the fuel filter needs replacement?
Old Nov 3, 2008 | 04:34 PM
RX8SaxMan's Avatar
From what I've gathered, the raspy sound is the result of poor ignition. This can be caused by bad spark plugs, wires, coils, fuel pump, or possibly low compression (i.e. new engine time).
So far I've done everything except replace the fuel pump and check my compression. It only happens to me when the engine components are hot, so either my fuel pump is overheating/wearing out, or my engine seals are losing compression due to thermal expansion.
I'll be posting here again when I figure out which one it is for my engine. For you, the coils are a good start, and you can use logical deduction from there.
Old Nov 4, 2008 | 07:22 PM
did you give my pm a shot?
Old Nov 4, 2008 | 07:27 PM
RX8SaxMan's Avatar
Not yet. I just haven't had time (school + work is kicking my ***). I'll try to get my hands on a bottle of MMO before my next fillup in a day or two.
LionZoo's Avatar
road warrior
I'd be interested in this solution as well swoope.
Old Nov 4, 2008 | 08:11 PM
me
what i suggested through pm was..
8 oz of mmo into a 1ltr aquafina bottle, add gas shake..
fill tank half way, add mixture. fill rest of the tank..( this is the kinder gentler premix)
if that solves the problem it is drying apex seals, motor time.. if not the next idea is fuel pump..
my first motor had this problem.. it worked well..
Old Nov 5, 2008 | 04:57 AM
Potentiated's Avatar
Wait, none of his posts specifically say he changed his spark plugs. I'm guessing he did but would like to hear it explicitly.
Old Nov 5, 2008 | 12:11 PM
RX8SaxMan's Avatar
Well the plugs I have aren't that old, so I did not replace them. I'm not saying they aren't the problem, but IMO it's unlikely. I'll probably pull them soon and inspect them, and maybe replace them again.
Old Nov 5, 2008 | 12:24 PM
LionZoo's Avatar
road warrior
Might want to change the plugs. If your coils were bad, it could've taken the plugs with them.
Old Nov 5, 2008 | 03:32 PM
RX8SaxMan's Avatar
So I mixed in some Marvel Mystery Oil to my fuel per swoope's PM, and my engine is running as smooth as snot so far. I don't want to jump to conclusions, though, because my raspy sound was always most prominent in hot weather, and today it has only been about 60 degrees out. I'll keep you all posted.
Old Nov 5, 2008 | 07:53 PM
Faxie's Avatar
My problem isn't exactly the same though... I can't say the car is running rough, idles just fine (850 rpm, very slight vibration) but when i go WOT in 3rd and 4th gear, I get these horrible rattles (like a hard disk drive, or a coffee machine) past 7000 rpm, and a blinking CEL when i keep it up for too long.
Stupid thing is.... it doesn't always happen.
I had the problem before, and it turned out one of the plugs was f*cked, so replaced all 4 of them. Problem went away after that, but after 5000 miles or so, it started again. So my guess is one of the coils is bad....
Car has 31000 miles now btw, and it's a 2005 6mt shinka.
Old Nov 5, 2008 | 09:28 PM
tunerwannab's Avatar
I want to see how this ends. Keep us posted and GL.
