Car is hard to start
Old Oct 25, 2008 | 08:40 PM
greg985's Avatar
The 337
This may have been answerd before but search didnt find much. Just recently my 8 has had a hard time starting. Doesnt mater wether the car is warm or cold, It has been taking about 3-4 sec of cranking to start the car, and the battery does not sound weak. I have a little under 42k miles on the car, I just had the RP HighFlow Cat instaled. I dont see how that could have anyhting to do with it.
Old Oct 25, 2008 | 08:48 PM
Easy_E1's Avatar
When were the spark plugs changed last? And have you ever changed the coils?
Old Oct 25, 2008 | 08:54 PM
greg985's Avatar
The 337
Mazda "says" everything was changed at 30k miles
Old Oct 25, 2008 | 09:35 PM
Low Fly'n 8's Avatar
Do you have the replacement high torque starter? How do you like the super cat / RB exhaust combo?
Old Oct 27, 2008 | 11:41 AM
greg985's Avatar
The 337
I do not have the starter, I love the SuperCat/RB exhaust
Last time I filled up I put a little too much pre mix in, could that be the problem?
Old Oct 27, 2008 | 12:07 PM
CyberPitz's Avatar
Huge hole is huge
If by 'a little' you mean three extra bottles, then that's not the issue.
I'd suggest it may be the starter, coils or plugs.
Old Oct 27, 2008 | 12:38 PM
Haze's Avatar
2 things:
One, I see that you have a K&N intake. When was the last time it was cleaned and reoiled, and if it has been in for a while you might want to clean the MAF sensor?
Two, if the car is idleing and running OK, then I would discount the sparks or coils as the problem, and I would think about high speed starter if you do not already have it.
Old Oct 27, 2008 | 02:03 PM
nvrfalter's Avatar
tonybob failpants
make sure that you have the updated starter.
Old Oct 27, 2008 | 02:08 PM
greg985's Avatar
The 337
Originally Posted by Haze
2 things:
I did buy the intake used from a member here so it may be a little dirty, but the car idels fine, i dont see how the intake could affect starting that much. Also where can I get the upgraded started? BHR?
Old Oct 27, 2008 | 02:23 PM
Haze's Avatar
A clogged air filter can cause starting issues as well as idleing issues because of the lack of air. That happens with the stock filter as easily as a K&N.
Upgraded starter is a TSB from Mazda. I got it for free before my warranty ran out. Not sure if your car is part of the TSB VIN range. If it isn't part of the VIN range then you have the starter already factory installed in your car.
Old Oct 27, 2008 | 02:55 PM
greg985's Avatar
The 337
Well I will clean my filter and see if that helps, I have to go to mazda to get a new shock put on soon, so I'll just ask them about it while I am there
Old Oct 27, 2008 | 04:05 PM
hakuna matata!
coils fixed my car taking 4-5 seconds to start (as well as eliminating high rev misfires).. my car now starts in 1 second flat.
Old Oct 27, 2008 | 05:57 PM
CyberPitz's Avatar
Huge hole is huge
My car only takes an extra second to start if it's REAL cold outside...
Old Oct 27, 2008 | 09:19 PM
cpo32's Avatar
Does anybody happen to know the name of the TSB. I'm having the same problem even after installing new coils, spark plugs, and cleaning my K&N filter
Old Oct 27, 2008 | 09:20 PM
ZumnRx8's Avatar
RX8 & RX7 owner
engine flood
Old Oct 28, 2008 | 12:26 AM
RotoRocket's Avatar
Freely Radical
Dealer rectified.
Old Oct 28, 2008 | 09:47 AM
EDZRIDE's Avatar
2005 White GT
It was TSB 01-048/06; unfortunatly, they have revised it, leaving out all the battery and starter information.
Old Oct 28, 2008 | 09:20 PM
cpo32's Avatar
Thanks for the help...here's a link to the old TSB
http://www.finishlineperformance.com...48-06-1691.pdf
Old Oct 30, 2008 | 08:36 AM
greg985's Avatar
The 337
Turns out it was a bad battery. The battery was only cranking at less than half power
Dokuji
Nov 1, 2016 02:51 PM
harithac
Jul 25, 2015 04:21 PM
dbarber
Jul 25, 2015 01:34 PM
dmac1961
Jul 24, 2015 11:27 AM
Kangarhew
Jul 18, 2015 08:27 PM
