How Do I open My headlights!!
Old Oct 24, 2008 | 12:35 PM
x8tuner44's Avatar
I wanna open my headlights, but I was told that you cant just open them with the method of sticking them into the oven. What is the way to open them up? Also I want to change my foglight bulbs, but my oil coolers are in the way. What do I have to do?
Old Oct 24, 2008 | 12:50 PM
initialsin's Avatar
https://www.rx8club.com/showthread.php?t=36067.html
Here is how to change out the fog light bulb, ill try and find a headlight one late but in class sorry.
Old Oct 24, 2008 | 01:47 PM
Aipex8's Avatar
X e p i A
Headlights can be baked, it's the taillights that can't. I don't know at what temp or for how long off the top of my head, but there are some threads about halos or angel eyes that give that info.
Old Oct 24, 2008 | 02:46 PM
Rotr8's Avatar
whines all the way home
Search for a screen name "shakeyourbrakes" he helped advise me on baking mine open I recently finished painting them black and later this winter I will bake them shut,,, heres mines so far.....
Bake open at 220dgrees for 8 min stints
Pry open and reapeat until open,,,,
I sprayed with High temp engine paint
High temp primer, higher temp semi gloss
Let paint set for recomended time (8-10) days
Reassemble and bake shut...
Attached Thumbnails How Do I open My headlights!!-cimg0384.jpg   How Do I open My headlights!!-cimg0390.jpg   How Do I open My headlights!!-cimg0397.jpg   How Do I open My headlights!!-cimg0398.jpg   How Do I open My headlights!!-cimg0383.jpg
Old Oct 24, 2008 | 03:05 PM
shakeyourbrakes's Avatar
yea i def have plenty of threads on baking the headlights...follow those directions above theyve been tested many times by me. PM me if you need help
Old Oct 24, 2008 | 03:07 PM
Old Oct 24, 2008 | 05:09 PM
x8tuner44's Avatar
Thanks everyone for your help, and Rotr8 do you really have to leave the headlights for 8-10 days. Ill have nothing to drive.
Old Oct 24, 2008 | 06:11 PM
overnight works fine..make sure not to seal them too quick though, the paint fumes create a mist on the inside of the lens, so you have to wetsand and refinish the plastic...trust me i had to do it when i left the paint for 4 hours to dry then sealed them like an idiot
Old Oct 25, 2008 | 03:49 PM
x8tuner44's Avatar
O ok thanks. Well does anyone know how to open the tail lights?
Old Oct 25, 2008 | 04:07 PM
Rotr8's Avatar
I bought two sets of Ebay and cut them both open then frankenstien them together, baking doesnt work the lense is ultrasonically welded together with a chemical bond
Old Oct 25, 2008 | 07:42 PM
x8tuner44's Avatar
Rotr8 What exactly did you do? Do the lights look cut up? Any pics of the install and progress of the work done? Sorry to be a pain, I just dont wanna screw it up.
Old Oct 26, 2008 | 09:17 AM
Rotr8's Avatar
dont have any pics, but on one set I used a knife edge to pry the clear shell off once I broke through teh lense, and on the other set I took a dremel and cut away the black plastic. In the end I had one good set of just the lense caps and one good set of the plastic housings, I still havent epoxied them together yet but will be painting them just like the headlights
Old Oct 26, 2008 | 09:40 AM
NgoRX8's Avatar
wow i had that exact idea of cutting up two sets of tails, but i've never been willing to try it. that's awesome man. good luck!
those headlights are looking pretty clean.
Old Oct 26, 2008 | 09:52 AM
Rotr8's Avatar
Thanks Ngo.....
the taillights are gonna be low profile too,,,,, for some reason I never felt the same about the strakes in the tailights as I did in the headlights, so Im cutting them out and filling the holes. After that painting all silver components the same black that I used in the headlights....
Old Aug 3, 2009 | 10:49 PM
SRrx-8JC's Avatar
Felix "The Man" Wankel
Ok so I have some sort of crap build up on the inside of my headlights. I am not running therisk of baking them just to clean them.
I was wondering could I make some sort of tool to clean the inside through the holes where the bulbs were. If so could i just use some windex in there or some sort of non streak stuff??
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
GK1707
Sep 27, 2015 07:33 PM
drlubell
Sep 26, 2015 11:58 PM
