need a lil help
Old Oct 17, 2008 | 09:43 PM
southjerz8's Avatar
need a lil help
hey i just installed my intake this morning. everything went good, so i thought. but now i have a issue where the car cuts off in the middle of me driving. could it be something i did wrong or didn't do. all of a sudden it just idles down and cuts off. I've just been putting it back in gear and then it comes back on.
any idea or suggestions.
i have a 04 mt.
and the intake is a simota.
thanks in advance 4 your help.
Old Oct 17, 2008 | 10:22 PM
jones75254's Avatar
Move this to "Issues/Prob's" Tech forum and you will get more hits.
If i were you i would go back and take everything out and re-install, checking all connections and such. Sounds like poss vacuum issue.
Old Oct 17, 2008 | 11:41 PM
13bturbofc's Avatar
400whp RX-7+05 RX-8=BROKE
the only thing i can think of is a loose wire connection at the MAF sensor or if the MAF sensor and intake are not mounted tightly the MAF could be bouncing around and giving false readings to the ecu which can stall the engine. double check connections and mounting
Old Oct 18, 2008 | 07:06 AM
Jon316G's Avatar
Grasshopper
Do you get a CEL?
If so, what is the code it generates?
Old Oct 18, 2008 | 10:02 PM
vacuum leak.
Old Oct 19, 2008 | 05:29 PM
southjerz8's Avatar
thanks guys. no cel. i just checked everything. the map sensor was a lil loose. it wouldn't fit flush, so i did the best i could. seems to be ok so far.
thanks again
spectre26
Aug 4, 2005 04:05 PM
mattmanp5
MW RX-8 Forum
May 21, 2004 02:02 PM
