Upgrades and mods for Rx8
Old Oct 17, 2008 | 03:00 PM
xvickx's Avatar
well i've been doin some research but im still not sure where to start
Should i start with intakes/exhaust or start with the suspension like swaybars and flywheels??
im new so, any advice will help
Old Oct 17, 2008 | 03:03 PM
quazmosis's Avatar
Chode
Let's start with what do you want out of your 8?
Old Oct 17, 2008 | 03:07 PM
xvickx's Avatar
ummmm that's kinda hard question to answer
anything and everything is good enough?
Old Oct 17, 2008 | 03:20 PM
quazmosis's Avatar
Chode
If that's the case start buying then. My statement meant, do you want to autocross it? Do you want to bolt on stuff just to be doing stuff? Do you want to increase in HP? Do you want improve the asthetics of it?
Old Oct 19, 2008 | 12:43 AM
abdullaRX8's Avatar
Abdulla RX8
i'm havin the same problems, i dont know what to get, i want to increase my hp and torque to at least 280 hp and 200lbs torque... where should i start?
without turbo/nitrous/supercharger
Old Oct 19, 2008 | 01:02 AM
greg985's Avatar
The 337
lmao, you could start with a new car
Old Oct 19, 2008 | 01:10 AM
matt5462's Avatar
Honda stickers!!!!!!!
Old Oct 19, 2008 | 01:11 AM
matt5462's Avatar
j/k RX-8's are great handlers, horse power not so much. Good luck with the mods.
Old Oct 19, 2008 | 01:51 AM
TopGear8's Avatar
mkuhnracing.com
You should start by searching and finding out that nobody has even gone over 220 without a turbo/nitrous/supercharger.
Old Oct 19, 2008 | 07:31 AM
Transam kid 01's Avatar
The anti-ricer
If you're looking for more power, but not FI, look at lightweight flywheels. That will be one of the only non FI items that will give the 8 significantly better acceleration. Talk to Charles R. Hill @ BHR if you want a good set up.
For handling, getting stiffer sway bars makes a huge difference.
And just for fun factor, the Axial Flow short throw shifter is a nice thing to have and it is fun.
Old Oct 19, 2008 | 09:14 AM
longpath's Avatar
How does the Axial Flow short shifter compare to the Mazdaspeed short shift kit that is available in Japan and via japanparts (I just saw it last night and am wondering if it's worth the trouble and whether it will make it harder for a newbie to learn shifting a manual transmission - my wife only knows automatics)?
Old Oct 19, 2008 | 09:44 AM
The anti-ricer
AFE SS is about 29% of a shorter throw.
MS SS is about 20% of a shorter throw.
AFE is $260.
MS is $443.
It's actually pretty easy to use, and quite fun. In the beginning, it will feel like the throw only went half way and is not in gear, but it is of course. I didn't think it was too difficult to change over from the stock, so I don't think you would have much of an issue. As for your wife, she may experience an issue in selecting the correct gears, because the AFE ss (and im sure the MS as well) makes the gear selects very close to each other.
I highly recommend getting the AFE SS.
If you're ever in N. NJ (Bergen County) let me know; I'll let you feel my car with the AFE SS.
Old Oct 19, 2008 | 09:47 AM
imput1234's Avatar
I ♥ Drifting!!!
spend money on track days, since you probably have no clue what it can do.
Old Oct 19, 2008 | 09:53 PM
abdullaRX8's Avatar
Abdulla RX8
im talking about 280 bhp not whp!
Old Oct 19, 2008 | 09:55 PM
greg985's Avatar
The 337
ok well 280 bhp = about 240? whp. Thats is a good bit more than all the bolt on possible will give you
Old Oct 19, 2008 | 09:56 PM
hakuna matata!
^ still not getting there NA.
Falken's Avatar
Drop it into 3rd
Same general problem.
Old Oct 19, 2008 | 11:38 PM
Japanparts.com's Avatar
JP replies
The FEED 4.77:1 Rear diff crownwheel/pinion will also make for much improved accelleration
GW
JapanpartsLLC
Old Oct 20, 2008 | 02:02 PM
The anti-ricer
GW
JapanpartsLLC
Link please. I may be interested
Old Oct 20, 2008 | 02:10 PM
ZumnRx8's Avatar
RX8 & RX7 owner
Like everyone with an RX8= start with a midpipe.....from Racing Beat. Then add the Hi Power HKS...less weight...with the REVi intake and REVi Ram duct from Racing Beat....and a flywheel....Royal purple oil.....Lighter Crank pulley (get the 3 if you want).....aftermarket header....altogether maybe 20 hp. u want an extra hp or so....get the ZEX or NX nitrous 50 shot....i heard people running 50 shots and i yet havent heard anything bad about 50 shots.
After that move to the suspension of the car....its not only about power....its also about handling and thats why 8/10 of us own an RX8....
Sway bars.Strut Bars.Cross Bars...cross braces....adjustable Coil over kit....Brake Kit from BREMBO (VERY VERY SEXY) or slotted rotors with HAWK PADS..
Old Oct 20, 2008 | 02:15 PM
ZumnRx8's Avatar
RX8 & RX7 owner
Which way are you heading? SHOW? TRACK? DRAG? DRIFT? They all have different roads
Old Oct 20, 2008 | 02:18 PM
greg985's Avatar
The 337
Originally Posted by ZumnRx8
Like everyone with an RX8= start with a midpipe.....from Racing Beat. Then add the Hi Power HKS...less weight...with the REVi intake and REVi Ram duct from Racing Beat....and a flywheel....Royal purple oil.....Lighter Crank pulley (get the 3 if you want).....and some headers....altogether maybe 20 hp. u want an extra hp or so....get the ZEX or NX nitrous 50 shot....i heard people running 50 shots and i yet havent heard anything bad about 50 shots.
ummm...we only have 1 header
Old Oct 20, 2008 | 02:22 PM
shaunv74's Avatar
Power!!
+1 for a track day or High Performance Driving class first. This will tell you what you want to do to your car once you find out what you like to do and what it needs.
Personally the RX8 is plenty faster than I am once I realized what it's capable of.
Old Oct 20, 2008 | 02:25 PM
ZumnRx8's Avatar
RX8 & RX7 owner
**EDIT DonE
Old Oct 25, 2008 | 11:36 AM
xvickx's Avatar
this sounds like the direction im goin to take
could ya gimme an estimate how much this all gonna cost?
