Taking care of the 8
Old Oct 17, 2008 | 02:49 PM
xvickx's Avatar
Talking Taking care of the 8
First and foremost im new to this forum, i just got my 8 about a month ago.
It's my first 8 and from what i've heard you really need to take care of the car to have it runnin at the best condition. So what are the ways?
I kno the basic of taking care of the car like change oils and fluids certain interval etc etc
but what other stuff do i need to do?
thanks in advance!
Old Oct 17, 2008 | 03:03 PM
quazmosis's Avatar
Chode
Redline at least once a day. Check the oil level frequently.
Old Oct 17, 2008 | 03:10 PM
xvickx's Avatar
ok that's a good start
nething else?
Old Oct 17, 2008 | 03:25 PM
dozer's Avatar
on his 3rd rx8
clay bar and wax...
Old Oct 17, 2008 | 03:26 PM
RIWWP's Avatar
Those are the critical 2. Redline to keep it clean of carbon, and check oil levels frequently (recommended every other fill-up), and keep it above 1/2 on the dipstick.
The 8 burns oil intentionally, so it is entirely possible for it to burn through it's oil supply and destroy the engine. Your rate of burn is probably different from everyone else on here, so get to know your 8 personally.
Other than that, read all the stickies here, and the TSBs at Finishlineperformance.com for some of the known issues to be aware of.
Old Oct 18, 2008 | 07:49 PM
XAreXAteX's Avatar
^ your sig is great.
Old Oct 18, 2008 | 07:51 PM
Renesis07's Avatar
Vtak just kicked in yo!!
redline once a day, look into premix. I dont do it but a lot of people swear by it.
Old Oct 18, 2008 | 07:54 PM
XAreXAteX's Avatar
When walking away from it and breaking your neck to look back at it...use caution.
Old Oct 18, 2008 | 07:59 PM
daisuke's Avatar
rotorized!!!
DO NOT rev past 4k until the engine temperature is sitting at full warm
Old Oct 18, 2008 | 09:38 PM
xvickx's Avatar
what brand of oil should I use?
Old Oct 18, 2008 | 09:45 PM
Renesis07's Avatar
I use 5w20, but a lot of users use 5w 30 or 10w 30.
Old Oct 18, 2008 | 09:51 PM
exsequor's Avatar
wipe me down
My theory is each time you make this mistake and go past when its cooold, you take a strike off the life of your 8!
Old Oct 18, 2008 | 09:55 PM
mysql's Avatar
Doppelgänger
If you want to take care of your RX-8, this is what I recommend:
1. Sohn adapter with 2 stroke oil (Or engine oil if you want).
2. Because you aren't injecting engine oil into the seals due to the sohn adapter, you're free to run synthetic oil without any worry.
3. AccessPort to increase oil injection rates and to decrease coolant fan activation temps.
4. Re-medy water pump to increase coolant flow
5. BHR radiator to increase cooling capacity
I also avoid 4k+ rpm till the car is fully warmed up (which does not mean oil temp gauge in the car!)
I like to change out the oil every 3k miles. Swap transmission/diff/coolant/spark plugs once a year, but that might be overkill
Old Oct 18, 2008 | 10:54 PM
Symbioticgenius's Avatar
You Dumbass!!!
This is some of the best advice I've seen thus far.
Bro, I think that you should make a maintenance thread seeing as how you have one of the most reliable turbo builds thus far.
Old Oct 19, 2008 | 09:50 PM
PTY RX-8's Avatar
Smile
i was recommended , beleive it or not, 20W=50. I live in Panama, wether here is like 94 all year round, it goes down to 78 fro, Mid Dec to Mid April, other than that, hot, hot, hot.
I also read here on this forum a mech recommended 20W-50. its thicker, will protect ur Engine.
Mazda wants U to use what they say 'cause they want U to go to them all the time.,
Old Oct 19, 2008 | 09:52 PM
exsequor's Avatar
wipe me down
I'd say you got good advice. Thicker oil is better for hotter climates.
Old Oct 25, 2008 | 11:46 AM
xvickx's Avatar
Yea i live in Southwest fl and it can get up to high 90s during the summer
ill look into this
xvickx's Avatar
That's an awsome guide!!! thanks!
Old Oct 25, 2008 | 12:03 PM
xvickx's Avatar
okkk i made this mistake a few time already
i didnt know before..
garhhh
Old Oct 25, 2008 | 12:33 PM
cody6766's Avatar
watch your tires! I can promise you that you will burn through your FRONT tires faster than you expect. Cornering hard is hell on the front tires especially, and cornering hard is what the 8 does best. Keep up on your tire rotations and you'll save some time between new rubber.
Clean the brake dust off your rims! I hate seeing a nice car with charcoal rims because the owner refuses to clean them
gwailo
May 14, 2024 06:57 AM
GARCIAC951
Sep 10, 2015 07:17 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
