Aftermarket O2 sensor or Stock O2 sensor?
Old Oct 16, 2008 | 08:26 PM
Rotor Gunnin' it's Avatar
OK guys recently my area it rained heavily and i don't know what i was thinking, but i went out with my 8 and ended up goin into a puddle. My car died in the puddle and i'm not too smart with cars so i tried to restart it again. I have an AEM Cold Air intake on my 8 and it probably sucked in water. I've researched about this for a while and the mazda dealer said it wouldn't run if water got in the engine, but some threads here said that water takes out the carbon in the engine. i think mysql said it in one of the threads about putting distilled water in his engine. Anyway my filter has had many days to dry but the check engine light is still on. i took it to autozone and mazda and both said its the O2 sensor before the cat. My question is if its better to buy another original O2 sensor from mazda or just buy one online. The one from the dealer is $304 and online on oxygensensorsforless.com its $100 for an aftermarket bosch one. I'm also thinking about getting an after market exhaust and a friend of mine told me that i will need to replace the 02 sensor with an aftermarket one anyway, but i'm not so sure. Any help on this is greatly appreciated. thanks
Old Oct 16, 2008 | 09:26 PM
You can get sensor from Mazda for much less than 304.
Onlinemazdaparts.com
or get it from Mazmart, leave them a message (forum vendor here)
Old Oct 16, 2008 | 10:04 PM
but do u kno if an aftermarket one is better because the aftermarket bosch one is $100 on the site i mentioned before, but i kno cheaper doesn't always mean its better
Old Oct 17, 2008 | 03:22 AM
your whole post does not make sense..
are you claiming the puddle hydolocked your motor and the front o2 sensor failed?
yet you dont mention year and mileage? why.. did you read the owners manual?
do you know what a warranty is? glove box! look learn.
Old Oct 17, 2008 | 04:11 PM
i've looked at the manual and read it over. The engine didn't hydrolock cuz its still working. my car is an 04 galaxy gray rx8 with 55,000 miles. i had an aem cold air installed. and everything was fine with the car, then the puddle thing happened. All i'm askin is if its better to just buy an aftermarket 02 sensor or if the original is best. the aftermarket is cheaper by about $200 and no splicing or anything is needed it says its a direct fit.
Old Oct 17, 2008 | 04:12 PM
and yes its the front 02 sensor
Old Oct 17, 2008 | 06:06 PM
rotary.enthusiast's Avatar
The Local Idiot
Wow, I don't even know where to begin
Considering the PCM relies on readings sent from the front O2 sensor to meter fuel properly, I would replace it with the OE.
Old Oct 17, 2008 | 06:26 PM
it is covered under the 5 yr 60k mile warranty that was extended for the 04s and 05s..
Old Oct 18, 2008 | 11:44 PM
part has been taken care of thanks guys for your help my 8 is runnin fine again
drebbrnator
Dec 27, 2018 07:02 PM
tbiggybig
Aug 13, 2016 06:30 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
MarkX
Jul 31, 2015 07:50 AM
MolecularConcept
Jul 26, 2015 09:09 PM
