Where to get feed from lambo sensor
Old Oct 14, 2008 | 04:39 PM
CraigRX8's Avatar
CraigRX8
As title suggests, where does it come into the car?
Old Oct 14, 2008 | 04:40 PM
Kane's Avatar
Senior Member
U mean Lambda?
The O2 Sensor in front of the cat converter.
Old Oct 14, 2008 | 04:48 PM
CraigRX8's Avatar
CraigRX8
hahahahah yes i do. i know where it is, but where does it come into the car, does it go straight to the ecu or what?
Old Oct 14, 2008 | 04:49 PM
Kane's Avatar
Senior Member
Yeah it plugs into the engine wiring harness I am 99.99999% sure.
That plug sits on top of the tranny.
Old Oct 14, 2008 | 04:50 PM
CraigRX8's Avatar
CraigRX8
so if i need a feed i can take it from the ecu. dont spose anyone knows what cable it is
Old Oct 14, 2008 | 04:51 PM
Kane's Avatar
Senior Member
What are you trying to do exactly?
An ODB2 reader can get it. I wouldn't know how splicing into it would work since the wires also control the heating element.
Old Oct 14, 2008 | 04:54 PM
CraigRX8's Avatar
CraigRX8
its a feed for a cage. whats the ODB2 reader
Old Oct 14, 2008 | 04:59 PM
Kane's Avatar
Senior Member
A Gauge?
You can't do it - the gauge (like an Autometer or Innovate) has the processor for the heating element in it.
The ODB2 reader is an electronic gauge www.dashhawk.com Plug and Play
Check it out.
Option 2 is to weld another O2 sensor on the car (I did my wideband that way). Cost's almost nothing.
Old Oct 14, 2008 | 05:01 PM
CraigRX8's Avatar
CraigRX8
not a bad idea kane. what feeds did you bring to the sensor?
Old Oct 14, 2008 | 05:03 PM
Kane's Avatar
Senior Member
I got the Autometer Cobalt Wideband it comes with the sensor and everything you need to hook it up as a standalone Wideband.
Then it has a data port option - so I could wire it into my EMS.
That Dashhawk can also log - but I don't think you can wire it directly to an aftermerket EMS. The Dashhawk plugs into the ODBII port under your steeering wheel - and then it gets all the feeds your car's computer has.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
