Im the Newb....
Old Oct 11, 2008 | 09:45 AM
Spoolin8's Avatar
Im the Newb....
Well guys i would first like to say Hi and this looks like a great forum. I live in Dallas Texas and i actually have a 04 rx8 (52k miles) in my possession which i plan on buying today however i had some questions. I noticed this red light come on twice while driving, the light is located below the oil temp gauge and looks like a intercooler or a old radiator and im not sure if this is normal or not for it to come on. Here is the carfax on the car so you guys can let me know if it looks like the car is up to date and if not what recalls am i missing?
http://www.carfax.com/cfm/ccc_Displa...FE173440130337
Thanks guys and i look forward to being a fellow 8 owner
Old Oct 11, 2008 | 09:57 AM
PotatoSoup's Avatar
Polish-American Hammarrrr
Doesn't sound normal, probably low coolant?
Old Oct 11, 2008 | 09:59 AM
Spoolin8's Avatar
which means the coolant could be leaking into the rotors which sets me up for a prime opportunity to take advantage of the 100k 8 yr engine swap?
Old Oct 11, 2008 | 10:08 AM
rglbegl's Avatar
Baned
Or it could be the sensor.
I have seen plenty of people start threads about the coolant light. Seems the sensor is overly sensitive.
Make sure it is topped off
Old Oct 11, 2008 | 10:18 AM
Spoolin8's Avatar
Ok i just opened up the coolant and it was basically really low lol so how high do i know to fill it to? Should i just fill it pretty much to the top?
Old Oct 11, 2008 | 10:50 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
There are actual marks on the reservoir bottle.............."F" and "L". Might be hard to see, but find them.
If you have a manual for the car, look on page 8-16.
If not, then make sure the car is cool when adding, the radiator itself should be full, and then the coolant level in the reservoir should be between the "F" and "L" mark. (Again..........when it's cool)
Old Oct 11, 2008 | 11:24 AM
Spoolin8's Avatar
Ok i just couldnt see them earlier, thanks for the heads up. Yea it was a little low and i just found the dealer invoice showing they filled the car with 10-30 instead of 5w-20 and the oil level was just above half way so im curious as to if the 10-30 is going to be problem and if not is it ok to just add 5w-20 or should i just drain the oil and refill with 5w-20 and just repeat 3k miles later?
Sorry for all the newb questions and i really do know how to use the search button but im just in a hurry right now since im trying to get as much info before going back to the dealer.
Old Oct 11, 2008 | 11:48 AM
chancejat's Avatar
Drive it like u stole it!
10w-30 is fine .....definitely not a problem in texas...
Old Oct 11, 2008 | 12:17 PM
User24's Avatar
All the dashboard lights come on, every time you start the car. That way you don't have to identify from memory.
Old Oct 11, 2008 | 01:10 PM
greg985's Avatar
The 337
how the dealer put something other than 5w-20 in your car
Old Oct 11, 2008 | 03:12 PM
CyberPitz's Avatar
Huge hole is huge
Dealer put 30 in my car. They were nice.
Old Oct 11, 2008 | 03:20 PM
JTtheDude's Avatar
Hey Spoolin, once you fill it up just keep an eye on it. When you drive the car hard it can sometimes cause the light to come on even though it's not low which indicates the sensor might be bad. Once it's full if it keeps coming it's probably the sensor. If you need any help I'm up in Plano just north of Dallas. Mine started coming on a few weeks ago when I would go WOT but it would go off shortly after, it was low, once I filled it the light hasn't come on since.
Old Oct 11, 2008 | 03:25 PM
Spoolin8's Avatar
I am in Plano/Murphy so thats good to hear. I just got back from the dealer and they wouldn't give me exactly what i wanted but they are desperate for business so come monday we shall see
Old Oct 11, 2008 | 05:29 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah 10w30 is perfect for texas and that light is a low coolant light make sure it's full when cool then check again when it'z hot (after thermostat opens) and all shoyld b good........pics or it didn't happen
Old Oct 11, 2008 | 10:56 PM
Spoolin8's Avatar
So when i do my next oil change should i use like castrol syntec full synthetic 10-30? Ive read several threads were people argue against synthetic for rotaries but i have yet to find a good clear answer, here are some pics of the car and basically what is going to come down to is whether i can get a loan with a good apr in todays market.
Old Oct 11, 2008 | 10:57 PM
Spoolin8's Avatar
i found another red one that is a little cheaper and has less miles but it does not have a spoiler or the red/black interior which i love. Basically after my current trade in (4,000 value) i looking to pay around 12k but with the current interest rate its saying ill be paying 16k overall so im trying to get a good deal.
Old Oct 11, 2008 | 11:04 PM
greg985's Avatar
The 337
what is that white spot on the front bumper
Old Oct 12, 2008 | 09:25 AM
JTtheDude's Avatar
When I get my oil changed I always specify 5w-20 non-synthetic. When you initially go in and get the paperwork for the guys to change the oil there is usually a comments/special request section. I always write down 5w20 non synthetic in this section to cover myself and make sure they put what I want in there. When I request this I have never been questioned by anyone to try and make me put something else in.
Old Oct 12, 2008 | 09:57 AM
Spoolin8's Avatar
bird **** its a black car so it has its fair share of sratches and some dents but all the dents look like they can be popped out with ease.
Old Oct 13, 2008 | 01:04 AM
Spoolin8's Avatar
Ok well i just found a 05 red one that just went up for sale for 1k cheaper with only 28k miles and a clean carfax report. The car is the velocity red which i am fine with and still has the red/black interior which i love but has no spoiler and im not sure but the rims may be smaller but look exactly the same. So i guess how much is the stock spoiler for the 8 or any other ones that look good.
Old Oct 13, 2008 | 09:00 AM
JTtheDude's Avatar
The spoiler is around 3-400?? I think? If the wheels are the smaller 16's it might be an auto rather than 6spd.
Old Oct 13, 2008 | 09:50 AM
Spoolin8's Avatar
well i am wrong about the wheels then because its def a manual. It just does not have the same lip spoiler as the black one so im guessing its the same as the black one just does not have the appearance package.
Old Oct 13, 2008 | 09:55 AM
JTtheDude's Avatar
Spoiler links....
OEM
http://finishlineperformance.com/sto...cat=267&page=5
Mazdaspeed
http://finishlineperformance.com/sto...cat=267&page=4
Old Oct 13, 2008 | 10:03 AM
dozer's Avatar
on his 3rd rx8
OHHHH DUDE that is funny **** welcome to the addiction!
Old Oct 13, 2008 | 02:36 PM
Spoolin8's Avatar
honestly this newer red one is a way better deal but my current car is red and i have always wanted a black car with a red/black interior so i am definitely addicted.
