View Full Version : Bolt and Nut Sizes--Exhaust
endowdly
10-10-2008, 07:41 AM
Does anyone know the bolt and nut sizes on the spring connectors between the midpipe and the muffler (catback)? Can't find it in search and I need to replace mine for... reasons. Thanks...
i'm guessing either 10 or 14 mm studs? which is it?
nuke0907
10-10-2008, 07:47 AM
they are studs not bolts. the nuts on mine seized. i tried looking at auto parts stores for days trying to find them but nobody had the right size. you will have to get them from a dealer unfortunately and they are about $9 each. you can try to see if the service department is doing a cat swap and see if the can give you the old studs from another car. thats what i did and the guy gave them to me for free.
endowdly
10-10-2008, 09:10 AM
yikes that sucks.
all i really need to know is if the studs and nuts are standard sizes. because if yes i can find them in a hardware store or make my own. and when i say size i mean internal diameter. i guess i really just need to know the stud size then, huh? lol...
Optical TDI
10-10-2008, 09:41 PM
If you don't want to use the springs then you can take one of the bolts/studs in to hardware shop. Find what nut fits on the end that go into the catpipe. Then you can use that to find the correct thread size, pitch, etc. I think the pitch was 1.25 and it was a metric bolt. That's what I just did and bought two 1.25 inch bolts that threaded perfectly into the catpipe. No springs though.
endowdly
10-11-2008, 06:28 AM
got it. thanks to nuke and optic for the help, really helpful to know that pitch.
for reference, it's a 10 mm stud with 14 mm nuts. <--that's what she said.
nuke0907
10-11-2008, 07:34 AM
i wouldn't suggest using just plain bolts. that joint is made to be flexible so you don't crack your manifold or something.
endowdly
10-11-2008, 10:32 AM
Yeah the springs on the stock joint help the rear assembly flex back and forward under stress. But, since the cat and muffler assembly are on hangers and can flex a little anyway--I don' t think damage will occur if just straight bolts are used.
chancejat
10-11-2008, 10:47 AM
i got bolts from home depot ....but i forget what size....maybe 5/8
