whats better 6x9 or 6.5...possible setup with 6.5 shallow sub in rear
Old Oct 10, 2008 | 01:05 AM
p-trix's Avatar
ive been doing some research on these for a while and upon research i hear that most people want 6.5 instead of 6x9 because of the bass and sound quality...then i found these 6.5 shallow subs by kicker and these 6x9 to 6.5 conversion plates...i might keep it simple and do regular 6.5 but this might be a good bass set-up
here it is
kicker 6.5 shallow sub
and the 6x9 to 6.5 conversion plate
so actually i have 2 questions
6.5 or 6x9
and
would this be a good setup
p-trix's Avatar
and also runa an amp to these
Old Oct 10, 2008 | 03:06 AM
rollerbldes's Avatar
You will have zero mid-highs in the rear with these. If that's what you want then sure go ahead.
You do plan on mounting these in place of rear speakers right?
Old Oct 10, 2008 | 11:00 AM
p-trix's Avatar
yeah
Old Oct 10, 2008 | 11:22 AM
Socket7's Avatar
ಠ_ಠ
I wouldn't be against using shallow subs in addition to other speakers, but if you replace full range speakers with something like this with a very limited range, you're going to end up with a hole in your frequency response. The rear speakers provide a lot of fill and body to the music, and you'll be loosing all of that.
Furthermore, sub's that small are not going to move enough air to get the oomph that I think you're looking for. Theres no substitute for a 10" or 12" sub.
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
