Why is my Signature disabled?
Old Oct 9, 2008 | 03:04 AM
Phoenix7's Avatar
Love those rotors
Hello, I click on the box to USE sig and it doesn't appear.
Thanks,
Hassell
Old Oct 9, 2008 | 03:11 AM
NgoRX8's Avatar
^your signature is right there
Old Oct 9, 2008 | 04:06 AM
Phoenix7's Avatar
Love those rotors
it doesn't show up for me. Thanks for letting me know, i dunno. I guess I gotta go play with the settings again, I guess it reset itself.
Old Oct 9, 2008 | 05:33 AM
alnielsen's Avatar
Yes, your sig is showing. There is a spot in your user options that you can turn off viewing sigs. Maybe that is checked.
Old Oct 9, 2008 | 08:29 AM
BlueEyes's Avatar
Maybe because it's too big...no wait, we don't enforce that rule.
Old Oct 9, 2008 | 10:29 AM
alnielsen's Avatar
The graphic in your sig appears to be to large in bit size.
Avatar & Signature Rules
1. Custom signatures are enabled, but any graphics used in such signatures are limited to a 20K file size with dimensions no larger than 500 pixels x 200 pixels.
2. Signatures are limited to six lines of regular text, including blank lines, or the equivalent size in picture, or picture/text combination.
3. There is currently no system to automatically check for signature size limits, so Admins and Moderators will be checking manually. Should your sig be found in violation, you will be asked to fix it; if you don't comply, it may be removed without warning. It is your responsibility to edit your sig and bring it within compliance.
4. Custom avatars are allowed, subject to a limit of a 8K file size and a 100x100 pixel image size. These limits are enforced automatically; the system will not allow you to upload an avatar image that exceeds them.
5. Banners or information linking to vendor sites ARE NOT ALLOWED in signatures unless the vendor being listed is a paying site vendor.
6. Signature and avatar content is subject to the same rules as forum posts. As a rule of thumb, if we won't allow it in a thread, it's not allowed in a signature. Moderators reserve the right to edit or remove any signature, avatar, or avatar caption as we deem necessary.
Old Oct 9, 2008 | 01:03 PM
Phoenix7's Avatar
Love those rotors
ok. I'll edit the sig and make it fit within the guidelines.
Thanks.
Omicron
69
Jun 26, 2019 04:53 PM
G8rboy
15
Mar 22, 2004 08:37 PM
pgtr
21
Nov 5, 2003 10:35 AM
