Spark Plugs RX7
Old Oct 6, 2008 | 06:34 PM
italyhot21's Avatar
Spark Plugs RX7
Hi guys
i wanna get rx7 spark plugs and put in my 8
but i heard they re bigger so
How much longer r they?
what can i use as a spacer?
Old Oct 6, 2008 | 07:07 PM
RufusVonStorm's Avatar
Yep, use those rx7plugs that's what I did!
You must use a spacer or you will do damage.
If you buy them from mazsport they come with shims already attached
Old Oct 6, 2008 | 07:37 PM
Icemark's Avatar
You only need a spacer for the trailing plugs (which don't make power so there is no need to change them unless you are using a non stock PCM).
The leading plugs you can use without any sort of spacer, as the crush washer on the spark plug spaces it out far enough.
But I don't get why anyone would want to change them to RX-7 plugs. The spark gap on a RX-7 plug is only .032 or so... considerably smaller than the .048 of the stock leading plugs on the RX-8.
Smaller gap = less spark
Less spark = less mileage
Less spark = less power
The only reason to use a RX-7 plug in the RX-8 is because you are too cheap to buy the correct plug for the car.
Old Oct 6, 2008 | 10:28 PM
^^+1
Old Oct 7, 2008 | 09:46 AM
dozer's Avatar
on his 3rd rx8
i dont understand....
Old Oct 7, 2008 | 10:05 AM
CyberPitz's Avatar
Huge hole is huge
You can use the plugs if you REALLY want, but I'd say stay with what comes with the 8...they are there for a reason.
Old Oct 7, 2008 | 10:30 AM
1.3L's Avatar
What's wrong with using the recommended spark plugs for the RX8? What is the benefit of using RX7 sparkplugs?
-1.3L
Old Oct 7, 2008 | 10:52 AM
CyberPitz's Avatar
Huge hole is huge
I guess he could have about 30 extra RX7 spark plugs and doesn't want to spend more money...?
Old Oct 7, 2008 | 11:07 AM
Icemark's Avatar
-1.3L
The one and only benefit from using the RX-7 plugs is that they cost only $5 -$10 each vs $20 each for the correct RX-8 spark plug.
RevMeHarder
Jun 1, 2026 02:30 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Irvinb16
Sep 11, 2015 10:27 PM
