LED fogs melt OEM housings?
Old Oct 6, 2008 | 12:09 AM
Rx8driver08's Avatar
I was interested in upgrading my yellow fogs to something with a little more light output, and i saw some LED bulbs that fit into the OEM fog lights, but i also read that LED's get really hot, and some people had trouble with them melting their fog housings. I was wondering if there is something else i could put in that would give me more output with out having to fabricate the OEM fogs to work an HID fog system.
Old Oct 6, 2008 | 12:11 AM
nvrfalter's Avatar
tonybob failpants
where the hell did you read that LED's get hot?
Old Oct 6, 2008 | 12:24 AM
czar's Avatar
Almost boosted
o_O i cant imagine anything being as hot as a normal halogen bulb ... led should be the coolest...a hid bulb runs cooler then a normal bulb (normal 35watt versions anyways)
only way i can see anything melting is if you went with higher watt bulbs
Old Oct 6, 2008 | 01:10 AM
SayNoToPistons's Avatar
Wheels, not rims!!
You're never going to get higher output with LED "bulbs" for your foglights.
Old Oct 6, 2008 | 01:55 AM
AJ's Shinka's Avatar
Enthusiast
In before the lock! LED's run cold.
Old Oct 6, 2008 | 10:14 AM
czar's Avatar
Almost boosted
lol there are leds that use heat sinks and use 3 watts but still ...alot colder then anything else
Old Oct 6, 2008 | 10:26 AM
NgoRX8's Avatar
LEDs don't run hot, and they also won't give you more output than the stock fogs. Better off with HID fogs.
Old Oct 6, 2008 | 06:34 PM
05rex8's Avatar
sold the 8... :(
I have these:
http://www.ijdmtoy.com/webpage/products/LED_bulbs.htm
Nothing but looks. Doesn't do squat, altho it matches my 6000K HID's pretty good.
In fact, I think I forgot to plug the foglights back in when I had my front bumper off for my turbo install....oh well.
Old Oct 16, 2008 | 12:53 AM
DARK R3's Avatar
F*ck a sunroof.
Thats what Im saying +1 ^
Old Oct 16, 2008 | 02:22 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Hahaha
High power leds, such as the cree 1000ma models get extremely hot. Without proper heat sinking they can get so hot that they destroy themselves.
With that said, any premade H11 led is going to be designed not to over heat.
Saying that leds don't get hot is completely false... you guys are just used to the little 20ma wimpy leds.
vapor2
May 4, 2020 03:53 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
