Mazda's Smart Idle Stop System. SISS
Old Sep 30, 2008 | 05:11 PM
ASH8's Avatar
Super Moderator
Attached Thumbnails Mazda's Smart Idle Stop System. SISS-siss.jpg   Mazda's Smart Idle Stop System. SISS-p1j04043s.jpg
Old Sep 30, 2008 | 05:54 PM
dynamho's Avatar
Is it only for automatic transmissions due to safety concerns?
For manual transmissions, the system could disengage the clutch and then set the piston position when speed gets to zero, no?
Old Sep 30, 2008 | 06:04 PM
chancejat's Avatar
Drive it like u stole it!
what does the piston being stopped in that position help?
Old Sep 30, 2008 | 07:29 PM
77mjd's Avatar
I don't get it. I'm assuming this is to save fuel?
Old Oct 1, 2008 | 04:06 AM
ASH8's Avatar
Super Moderator
Yep, it is to save fuel, at idle.
I assume it would be for both auto and manual transmissions and is ECU controlled via gas pedal.
I guess the piston stops in the centre or middle position so there is enough capacity by volume to "Squirt" or atomise enough fuel and then ignite, you have to remember this process takes only a few tenths of a second to start up engine.
Old Oct 1, 2008 | 09:13 AM
77mjd's Avatar
I take it they couldn't do anything like this for a rotary. Idling a rotary is absolute murder on gas. Something like this would help tremendously. It'll be interesting to see how the direct injection on the 16x helps mileage.
Old Oct 1, 2008 | 10:03 AM
dynamho's Avatar
To better explain the piston stop position, imagine that you're on a bicycle.
Also imagine that the pedal crank is at 12 o'clock and 6 o'clock. It would be tough to get going without pushing off wouldn't it? Now imagine that the pedals are at 9 o'clock and 3 o'clock. It would be much easier to get going from this pedal position. You wouldn't need much less external assistance, like pushing off (or an electric starter in Mazda's case).
Old Oct 1, 2008 | 10:30 AM
bulletproof21's Avatar
^good analogy
Old Oct 1, 2008 | 11:52 AM
dozer's Avatar
on his 3rd rx8
^+1.
Old Oct 1, 2008 | 02:10 PM
MattMPS's Avatar
Wiseguy
i've read somewhere that it's only for AT transmission...but i don't know if is it true or not.....
Old Oct 2, 2008 | 04:39 PM
ASH8's Avatar
Super Moderator
http://www.autoexpress.co.uk/carrevi...da-3-siss.html
"Mazda plans to use this technology on petrol engines before applying it to a new 1.6-litre rotary unit, due in 2010"
I don't think the writer of this story has this one correct, I am almost certain the SISS will not transfer to the 16X.
Old Oct 2, 2008 | 04:54 PM
CyberPitz's Avatar
Huge hole is huge
How the hell could they do that to the 16x? If it does happen, rocking.
And 2010 release for the engine? That seems..early?
Old Oct 2, 2008 | 05:13 PM
Spinning Sushi's Avatar
I <3 Sushi
^ Constant flooding ftw!
Old Oct 2, 2008 | 06:17 PM
solito's Avatar
Noice.
Old Oct 2, 2008 | 06:57 PM
CyberPitz's Avatar
Huge hole is huge
What if before it shuts all the way off, it does a "fuel cut" on that rotor for a few revolutions then stops it so no flooding?
Jesus Martinez
44
May 6, 2025 08:09 AM
drebbrnator
Dec 27, 2018 07:02 PM
Redheddude222
Aug 24, 2015 09:14 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
marc2820
Jul 26, 2015 10:47 PM
