Need Opinions
Old Sep 27, 2008 | 01:17 PM
FoXrAcEr2569's Avatar
Need Opinions
I need Opinions on what to do with the front of my car.
I talked to Scott down at Mazsport and discussed this hole that i might get
cut into the bumper cover it will help w/ feeding fresh air into the turbo rather then having it suck up all the hot air produced from the radiator and intercooler. The design is the same as Marcos Acosta's Rx8's
Here to make things easier I'll post pictures. Any comments will help.
Even if it's harsh, the hole seems to be a like it, or don't kinda thing.
Thanks, Jared
This is the car now:
This is Photoshopped:
the rest are pics of what the Vent hole is supposed to look like since my abilities in photoshop aren't that great.
Old Sep 27, 2008 | 01:38 PM
nvrfalter's Avatar
tonybob failpants
eh i dont like the hole. car looks hot tho. you should just get a vented hood to help with cooling
Old Sep 27, 2008 | 01:49 PM
imput1234's Avatar
I ♥ Drifting!!!
that car looks badass, but I'm not sure about the hole
Old Sep 27, 2008 | 01:52 PM
Phalkhan's Avatar
I like it, as long as you use the carbon fiber hood with it. The Vertex kit, in my opinion, is just too clean to have a hole in it without other aggresive aero items.
Old Sep 27, 2008 | 02:03 PM
chrism's Avatar
Misfit Moderator TnC
which kit do you have?.....doesnt the mazsport kit have the filter by the drivers side oil cooler?.....if thats it then a hole there is a waste and will destroy the kit
Old Sep 27, 2008 | 02:15 PM
m108kos's Avatar
not so muchhh
Old Sep 27, 2008 | 02:25 PM
Yeah, it does usually. Scott said that having the air filter up top where that hole is would eliminate a bend, and it would feed fresher air into the engine since it's not mounted near the Radiator, Oil cooler, and IC.
Old Sep 27, 2008 | 02:36 PM
Renesis07's Avatar
Vtak just kicked in yo!!
I think a hole like deedubs would look better. I think the rotary shape and circular hole is overkill.
Old Sep 27, 2008 | 02:44 PM
mysql's Avatar
Doppelgänger
measure underhood temps before assuming you need to do anything like this.
a bend in your CAI isn't going to hurt.
Old Sep 27, 2008 | 02:57 PM
thebiggdaddy's Avatar
A definite no.
Old Sep 27, 2008 | 02:58 PM
Rotr8's Avatar
whines all the way home
yuk that hole looks horrendous,,,, do this it look mch better you can find it on EVO-R, this is a pic of Klepto's car...
https://www.rx8club.com/showthread.p...ng+all+burnout
Its made for a 350Z,it may not fit the contour of the Vertex but Im sure you can fab it up to fit...
Old Sep 27, 2008 | 03:24 PM
chrism's Avatar
vertex will look better with a squared off hole rather than circular because of the shape of the kit....
Old Sep 28, 2008 | 09:21 AM
thanks for all the input guys, good thing i started this thread.
I called my fiberglass guy right after i started it.
Is the VIS hood a good idea?
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
Digitz0070
Oct 7, 2015 12:43 PM
Austin22
Sep 23, 2015 04:46 PM
