check engine light...please help!!!
Old Sep 26, 2008 | 11:56 AM
Bunso_Rx8's Avatar
Wednesday morning, I drove my car to work without the CEL. When i went on lunch and turned the ignition on, the check engine light came on. So i figured it was just the oil change because it was past 3,000 miles. Okay, so i got a oil change to the dealership and check engine light still on. The dealeship said they could check what is wrong with it but its going to cost me $127. I did a search and a lot of people here said that i should go to autozone to get it scanned for free. I'm going today and get the code.
Old Sep 26, 2008 | 12:03 PM
Jon316G's Avatar
Grasshopper
If the CEL came on when you first turned on the ignition, its more than likely the gas cap.
Give it a couple more turns and allow a couple drive cycles to clear the CEL (or disconnect the battery for 30 minutes).
Take it to Autozone and get the code pulled.
If it comes back that there is a small EVAP leak, it's definitely the gas cap.
Old Sep 26, 2008 | 11:04 PM
Bunso_Rx8's Avatar
I went to autozone this afternoon and got the code: P0456. you are right it is saying a small EVAP leak but i dont know what that is. If it was a EVAP leak, what should i do so fix it?
Old Sep 26, 2008 | 11:12 PM
DOMINION's Avatar
I don't buy Kool-Aid
New gas cap from your mazda dealer. Tellem to fix it! lol
Old Sep 26, 2008 | 11:21 PM
Jon316G's Avatar
Grasshopper
Yes... its the gas cap.
Either you didn't tighten it after your last fill-up, or its time for a new cap like Dominion said.
Old Sep 26, 2008 | 11:26 PM
greg985's Avatar
The 337
127$ to full a damn code, that is really pathetic
Old Sep 26, 2008 | 11:28 PM
Either get a new revised gas cap OR
take your gas cap out, wipe it CLEAN with a couple piece of bounty towel. u'll be shock of how "clean" your bounty will be.
then just put it back.
Oh your question. that code is a small EVAP leak.
small EVAP leak usually means a faulty gas cap. Cuz when you're not driving your car. the car's computer will pressure test the fuel system itself. it will monitor the fuel tank's pressure for a couple of hours. if there are any pressure lost, depend on how much, will throw you a small leak, a leak, or a BIG leak code.
Old Sep 27, 2008 | 12:12 AM
I8U's Avatar
I8U
Or you can just buy a new one from Rosenthal Mazda online for 12 bucks plus shipping.
Old Sep 27, 2008 | 04:26 PM
Bunso_Rx8's Avatar
I got the check engine light problem solved. I disconnect the battery for about 30 and after that CEL was gone.....Thank you guys for all your help
Old Sep 28, 2008 | 09:01 PM
I8U's Avatar
I8U
It'll will come back on for the same thing. If it does, buy a new gas cap...problem solved.
xAgyex
Jun 3, 2026 03:47 PM
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
