Replacement core
Old Sep 26, 2008 | 10:57 AM
tblair's Avatar
Replacement core
Hello all. After a recent tropical storm, I drove into a pool of water which I didn't see and hydro-locked my engine and need to purchase a replacement/rebuilt core. I have located one at Mazmart in Atlanta, but shipping to Jamaica is prohibitive.
Does anyone know of a source for a rebuilt core in the Miami area? The car is a 2005, 6MT which was originally purchased from Japan. I will ship my core up in part exchange if possible.
Old Sep 26, 2008 | 11:19 AM
You dont need to replace ur engine just because it has water in it.
un-screw the plugs, hand turn the engine or just keep cranking it till some water comes out, leave it like that under the sun for a few days (or leave a fan around blowing it for a few days.
replace it with new plugs and crank, it should fire up.
Old Sep 27, 2008 | 09:15 AM
olddragger's Avatar
tat would be the 1st hydrolocked rotary engine i have ever heard of!!
OD
Old Sep 28, 2008 | 12:14 PM
tblair's Avatar
I already tried that and it but it is jammed solid.
It happened about 2 weeks ago so it has had plenty of time to dry out.
Old Sep 28, 2008 | 03:01 PM
ken-x8's Avatar
Why is Atlanta to Kingston shipping so much more expensive than Miami to Kingston?
Old Sep 28, 2008 | 11:48 PM
tblair's Avatar
Miami to Kingston is direct by sea, while Atlanta to Miami adds several hundred for overland trucking.
Old Sep 29, 2008 | 12:33 AM
Jammed solid as in ?
starter not turning? or wont start ?
Old Sep 29, 2008 | 11:13 AM
mazdaverx7's Avatar
RX-Heaven
remove the plugs and try and bump the starter. i.m not sure that you could have bent anything internally causing the engine freeze...
Old Sep 29, 2008 | 02:51 PM
tblair's Avatar
Starter won't turn the engine. Tried using a spanner but it is frozen. Seem to have bent something :-(
Old Sep 29, 2008 | 02:52 PM
tblair's Avatar
Did that and also tried usng a spanner to turn the engine. Jammed solid.
Old Sep 29, 2008 | 11:05 PM
mazdaverx7's Avatar
RX-Heaven
i dont know what could be jammed..i guess an apex seal could have dislodged and jammed itself between the rotor and the housing but i figure you'd snap the apex seal when really prying..which ultimatly would end in a new engine..are you sure the trans is out of gear when you are attempting to turn the engine by hand? are you sure the starter is working properly and is not fried? a bad starter solenoid will not kick out the bendix and thus will trick you into thinking that the starter is not turning the engine.
TJSiegrist
Sep 10, 2015 09:29 AM
ed0128
Sep 9, 2015 04:50 PM
just1jack
Sep 9, 2015 04:45 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
