fiberglass
Old Sep 26, 2008 | 12:08 AM
luv4eternity's Avatar
Low is a lifestyle
fiberglass
1 question : is fiberglass good ? bad ? or ok ?
Old Sep 26, 2008 | 12:32 AM
romycha1's Avatar
Good or bad for what?
Old Sep 26, 2008 | 01:40 AM
remixlp's Avatar
um bad? Its all about quality. You get what you pay for.
Old Sep 26, 2008 | 03:09 AM
Low is a lifestyle
for bodykit
Old Sep 26, 2008 | 03:10 AM
Low is a lifestyle
oh really ? ...i guess thats about it ...thx
Old Sep 26, 2008 | 06:50 AM
chrism's Avatar
Misfit Moderator TnC
what a short and stupid answer.....wow....try searching for the real answer other than ignorant posts..here is a good comparison to fiberglass and poly
Overview of the Two Materials
Urethane is flexible but very difficult to customize or repair in any way.
Fiberglass is rigid but can be readily repaired or customized by a competent shop.
Points to be Considered
Purchase Cost
Fitment
Ability to Customize or Modify
Cost and Ability to repair
PURCHASE COST
If you are purchasing a quality part or kit, the urethane products are probably going to be slightly more expensive.
FITMENT
Generally speaking, a urethane product will fit a car slightly better right out of the box due to the control in the manufacturing process.
However, a urethane product CANNOT be fitted as exactly as a fiberglass part. Fiberglass products usually require trimming or filling during installation.
ABILITY TO CUSTOMIZE OR MODIFY
A good custom shop can modify or customize ALL fiberglass products. Fiberglass is a material that can be shaped, changed or fitted to any application. These mods can be reinforced to produce significant strength and durability. Urethane cannot be reworked or modified with any degree of durability.
COST AND ABILITY TO REPAIR
Urethane parts are flexible and will absorb very small 'hits' without creating serious damage (cracks or holes). However, once urethane is cracked in any manner, it is usually sent to the scrap pile out back.
Fiberglass parts are totally repairable. Most damaged parts, within reason, of course, can be repaired by any shop experienced with fiberglass. Proper repairs on fiberglass parts are durable and should be permanent.
Let's look at a repair cost scenario on a full bumper replacement kit.
Suppose there are a couple of good sized cracks in the front bumper. Normally, with a urethane kit, the bumper will need to be replaced.
Usually, the part cost is approximately $425.00 + $125.00 (average) in shipping. The labor to remove/replace and paint will be a constant cost in either replacing or repairing. There will probably be a time delay of up to 4 weeks until the replacement bumper arrives. The same cracks in a fiberglass bumper can probably be repaired immediately for a labor cost of $150.00. In most cases, unless the damage is very severe, this means a savings of $400.00 to repair a fiberglass front bumper rather than replacing a urethane bumper.
taken from
http://www.wickedbodies.net/FAQ's.htm
Old Sep 26, 2008 | 07:22 AM
remixlp's Avatar
LOL calm down buddy, I was being sarcastic due to his search efforts. Now, chrism is correct, but take into consideration the authentic vs replica debate as well when you are ready to purchase your kit, regardless of the material. You wouldn't want to be in a position where you end up shelling out twice as much cash because you went the cheap route.
Old Sep 26, 2008 | 09:23 AM
Rotr8's Avatar
whines all the way home
another post that doesnt even require this forum ,, google could have answered this.... These effortless post are getting old and clog the system to finding quality info.......
Old Sep 26, 2008 | 10:46 AM
quazmosis's Avatar
Chode
Yeah Fiberglass is great for boats here in the midwest.
ouimetnick
25
Sep 14, 2023 01:44 PM
yapakanichi
Sep 17, 2015 04:23 AM
mitchrx8
Sep 13, 2015 08:05 AM
RZ1
Aug 24, 2015 01:04 PM
