Kmeleon
09-24-2008, 03:13 PM
I recently replaced the stock wheels on my car, which results in a lot more of the rotors and calipers showing. I'm thinking with my black car and black wheels, it'd look a lot nicer with drilled rotors and the calipers painted black. So I'm thinking about trying to do it myself and replace the brake pads at the same time. I've read some of the DIY threads on the forums and read through Robin Yang's site, but I'm still wondering if this is something I can tackle. Do people have any insight or tips? The caliper painting definitely looks easy, but the rotor replacement sounds like it might be more complicated. And I'm especially worried about having to force the rotors off if the car is on jack stands. Here's sort of the process I'm envisioning...
1) Loosen lug nuts
2) Jack car up, place on jack stands (2 in front, 2 in back)
3) Completely remove wheels
4) Remove caliper bolts and tape calipers up
5) Clean calipers with metal brush, degreaser
6) Paint calipers with G2 caliper paint kit, two coats, allow to dry
7) Remove brake pads and replace with ceramic (brand???)
8) Remove rotor screws
9) Remove rotors (potential for banging with rubber hammer)
10) Clean hubs, install new rotors (brand? suggestions???)
11) Reassemble everything
12) Tires back on car, lower from jack stands
Also my car is automatic but it's the Grand Touring that had 18" stock wheels, so I think I need the sport rotors in the front, but I was hoping someone could verify.
And people who have used the Polak RX-8 decals on painted calipers... Do they hold up fine as decals on top with the heat, or am I better painting a white base coat and letting it show through with the RX-8 letters when I do a black top coat?
Any help or insight anyone has would be really appreciated. Including "you sound like an idiot, go to a speed shop."
1) Loosen lug nuts
