Engine Temps II
Old Sep 22, 2008 | 09:45 AM
elf's Avatar
elf
What pointy ears?
Engine Temps II
I tried the DEI Radiator Relief (same purpose as Redline Water Wetter, Royal Purple ICE, etc.), but it didn't help much in the engine cooling department in my case. Maybe with a higher water proportion in the coolant mixture it would have been more effective (I'm running a 60/40 mix). I'll definitely reinvestigate this at my next engine coolant change. Also, this little experiment was cut short because it started cooling off around here --- wish I gathered more data
I have the Mazmart RE-medy water pump sitting in the garage (for months now), so I'll eventually work that in somehow.
Recording Conditions:
* Same as Part I: https://www.rx8club.com/series-i-tech-garage-22/engine-temps-115456/
* Coolant mix: 60/40 (water/antifreeze)
Cowardly Disclaimer:
Same as Part I: https://www.rx8club.com/showthread.php?t=115456
Old Sep 22, 2008 | 10:58 AM
olddragger's Avatar
thats a real interesting finding there---good work.
olddragger
Old Sep 23, 2008 | 10:48 PM
Delmeister's Avatar
Nice! Above 80F or so, the coolant temperature change tracks almost one for one with the ambient change. This suggests the thermostat is already wide open at this point.
Old Sep 23, 2008 | 11:13 PM
interesting stuff Elf!
you should go 70/30
Old Sep 24, 2008 | 03:16 AM
that stuff will never help much
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
Nisaja
Aug 6, 2015 01:27 AM
RotaryRider
Jul 20, 2015 07:05 AM
