NW RX-8 Forum Serving WA, OR, ID, AK
motor swap
Old Sep 18, 2008 | 01:46 AM
2slow's Avatar
motor swap
how much work does it take to drop a 20b into my rx8..just tryin to figure some stuff out...really appreciate some feed back
Old Sep 18, 2008 | 11:25 AM
pdxhak's Avatar
Official Post Whore
you have a 13b where you live has a LOT (emissions = $$$$) to do with the costs.
Old Sep 18, 2008 | 11:38 PM
2slow's Avatar
last post was just a lack of brains...never post a foroum when yur fallin asleep
Old Sep 18, 2008 | 11:58 PM
tunerwannab's Avatar
i've heard 20k plus. depending on what u can do yourself. Luckily for me my fiance said when we both graduate college i can do the swap before we buy a house.
Old Sep 19, 2008 | 01:38 AM
ZumnRx8's Avatar
RX8 & RX7 owner
20b For $5k
I KNOW A PLACE WHERE U CAN BUY A 20B TT OFF A 95 COSMO 30-40K MILEAGE, WARRANTY, W/ TRANNY AND ALL WIRING. NO WIRING CUT FOR $5K, AS FAR AS SOMEONE DOING TO THE WORK>? ULL HAVE TO ADD THAT ON TOP...... TRY TO FIND A SPONSOR FOR THE WORK...FIRST BUY THE ENGINE AND TRANNY. THAT WAY ULL HAVE SOMETHING TO NEGOTIATE WITH FOR THE SPONSOR.
LOOKS LIKE U HAVE UR CAR GOING
IM IN CALIFORNIA
PM ME
Old Sep 19, 2008 | 10:00 AM
2slow's Avatar
ive had an offer from a local shop...dont know if they're legit
Old Sep 19, 2008 | 10:42 AM
pdxhak's Avatar
Official Post Whore
You should look into Pineapple Racing in Portland.
Old Sep 19, 2008 | 12:49 PM
What shop?
Old Feb 13, 2009 | 04:53 PM
AngryBumblebee's Avatar
The Bawss
atkins rotary
Old Feb 13, 2009 | 05:20 PM
angeljoelv's Avatar
angeljoelv
ya 5000 for the engine... But thats only the start. A lot more than that to put it in your 8. Trust me, I would know.
Old Feb 13, 2009 | 05:31 PM
bose's Avatar
Reginald P. Billingsly
^^^Listen to him.
Old Feb 13, 2009 | 05:39 PM
TheBri's Avatar
Spastic Monkey
Yes. Yes he does.
If you do it right you're going to wind up replacing basically the entire drivetrain - motor to wheels.
Old Feb 13, 2009 | 06:08 PM
RawrX8's Avatar
Grocery Getter
I thought about this but not till my warrenty goes dry. Ill just do a 5.3l rear mount turbo instead.
So the big money is just the motor, tranny (or mod bellhousing and use a T56) and rear dif? Or are the shaft to weak too? Fuel pump, lines, oil coolers, ignition system thats all the smaller stuff.
Hate me for this, but 20k sounds like a farfetched number unless you take it to a shop. For that kind of money you could link 2 13Bs and going extreme throwing a motec 800 with some left over for a trip to hawaii.
Old Feb 13, 2009 | 07:46 PM
risky business's Avatar
IRC Founder
no no no, you actually only need 10k for the engine and swap... the extra 10k is for hookers and dancers to keep you busy while you dont have a car because its in the shop getting a new engine..... it could take awhile so better budget about 10k for the women.
Old Feb 13, 2009 | 10:57 PM
RawrX8's Avatar
Grocery Getter
I have access to plasma cutter, mig and tig welders. As long as the rear dif will hold up which it should seeing how guys at putting 350 with the turbo kits now. So just mating it with a transmission, fuel and new ignition systems is the money.
Taking your car to shops is like getting herpies from a hooker though.
Or someone bust my bubble cause it really doesnt seem like a expensive or hard swap. Well maybe for people who cant change their own oil
Old Feb 13, 2009 | 11:56 PM
Not everyone has the tool or knowlege to rebuild their engine bay just to start with. Not to mention little things like the throttle control steering, weither or not u want things like a/c, power steering, factory gagues, or DSC to still work.
What ever u do dont listen to angeljov he has absolutely no clue what it takes to make it all work.
Old Feb 14, 2009 | 01:29 AM
angeljoelv's Avatar
angeljoelv
My engine was 3500 when I bought it ended up costing me like 7G's after rebuilt. Im hoping you want to rebuild it or should i say "refresh it" before puting it in there... right?
Old Feb 14, 2009 | 01:34 AM
angeljoelv's Avatar
angeljoelv
in other words. if the engine cost you 5000 and you do it right , you would spend and extra 3000 between partes and labor to have the engine ready to go. So that my friend alone is 8000.. I spend well over 2 grand only in fittings and lines. Plus, ignition system ( mine was over a grand), Ecu, motor mounts, turbo manifold, turbo, intercooler, piping, downpipe, wastegate, BOV, fuel pumps, filters, regulator , injectors..... mmm and lots more.. If you are planning to do it right from the start that is... If you want to cut corners, WEllll you just going to spend more money , becouse you are going to need all this sooner or later... Ohh and have a couple of extra trannies, rear ends available... And of course a lot of hours into the swap
Old Feb 14, 2009 | 01:30 PM
RawrX8's Avatar
Grocery Getter
Do you use the rx8 tranny or is there a better match?
Old Feb 14, 2009 | 06:50 PM
angeljoelv's Avatar
angeljoelv
rx8 tranny matches perfectly. The only problem is the 20B has to much torque. If you take it easy it holds for a while. The problem is its very hard to take it easy knowing you have a monster... \hahahaha
Old Feb 16, 2009 | 05:52 PM
The Bawss
some guys use the 5 speed fd tranny right?
Old Oct 8, 2010 | 10:08 PM
mazdaRacer8's Avatar
so if i get a 20b tri my stock tranny will bolt right up to it. how much mods would i have to do for the motor mounts ?
Old Oct 9, 2010 | 12:09 AM
Nemesis8's Avatar
Bigus Rotus
dude - if you have to ask....
Old Oct 10, 2010 | 04:02 AM
shin's Avatar
So are you gonna turbo yout car by yourself rawrx8?
Old Oct 11, 2010 | 07:21 PM
hornbm's Avatar
t56 is what you are looking for. However there a ton of options you can go with for getting the RIGHT t56.
The 20B FD guys have been using t56's for a while now with great success.
However, I know angeljoelv had a t56 at one point and broke it, so take that for what its worth. I'm fairly confident it can be done, if done right. There's a zillion ways to do a t56.
