Derex'8
09-17-2008, 04:52 PM
Ok I've searched and searced and still san't seem to find a straight answer.
Has anyone took the exact measurements of the "Inside Diameter" to the stock intake and MS/AEM intake?
This info would be much appreciated TIA!!!
05rex8
09-17-2008, 07:06 PM
I don't know about stock, but I think the AEM/Mazdaspeed is 3.5" because the FI guys can use it if they are using the cobb acessport
Jon316G
09-17-2008, 08:57 PM
On the AEM intake:
The upper inlet pipe is 3.5
The lower inlet pipe is 3.25 for the air filter assembly
rotarygod
09-17-2008, 09:14 PM
Either way it's far more airflow capability than the engine can ingest so hopefully you aren't thinking about making it larger.
simplyphp
09-17-2008, 10:47 PM
Silly rotarygod, bigger is better and a 4.5" intake diameter would allow greater speeds to be reached at lower rpms. :lol:
Derex'8
09-17-2008, 11:23 PM
....No not @ all need it for tuning purposes, using a 1:16 scale I measured the ID of the AEM maf housing tube @ approximately 3 3/8 in.....85.7 metric
