View Full Version : How to lower the turn signal blink rate?
k8sp3r
09-14-2008, 03:36 AM
Does anyone know how to lower the turn signal blink rate? A buddy of mine just installed new LEDs for the turn signals and they blink too fast, gets annoying after awhile. Help will be most appreciated...
StealthTL
09-14-2008, 03:40 AM
LEDs have very little current, which causes the rapid cycle.
Most LED kits come with resistors that fit in parallel (not series) with the bulb, and put load on the flasher.
Alternatively, if you can find the flasher unit (I'n not sure where it is) you can replace it with an 'electronic/trailer' one - they flash at the same rate no matter how many, or few, bulbs in the circuit.
S
alz0rz
09-14-2008, 12:19 PM
http://cbrworld.net/forums/thread/141166.aspx
Razz1
09-14-2008, 01:27 PM
Thanks Stealth... I didn't know you could buy an eletronic trailer flasher.
laythor
09-14-2008, 01:29 PM
I use http://www.stealthauto.com/Departments/Shop-By-Category/Stealth-Bulbs.aspx for my flashers
NgoRX8
09-14-2008, 05:50 PM
flasher or load resistor.
greg985
09-14-2008, 07:19 PM
this is what you need :lol:
http://kalecoauto.com/index.php?main_page=product_info&products_id=6
