Problem with my Cruise Control!!!
Old Sep 11, 2008 | 08:09 PM
rotarydrifter's Avatar
I had just finished installing some hks coilovers, and for some reason my cruise control doesn't work...
the Yellow "Cruise On" light comes on, but the Green "CRUISE" light doesn't come on so the cruise control doesn't set...
im thinking that wen i was putting in the coilover i must have put stress on the speed sensor and must have loosened...
and YES i HAVE BEEN USING THE "SEARCH" option....
i read that if i damaged the sensor my dsc and abs light would come on...but theyre not on....
Old Sep 12, 2008 | 05:58 AM
DOMINION's Avatar
I don't buy Kool-Aid
From the center, turn your wheel all the way to the left then all they way to the right and back to the center. That should reset it
-Gil
Old Sep 12, 2008 | 07:11 PM
I tried it...with the car on and with just the ignition...but nothing... its still on i was searching related threads n found something about a brake switch and clutch switch because the cruise control can not be set if those switches are not working properly...but uhhh how do u make sure its not those???
Old Dec 19, 2008 | 10:39 PM
i ended up taking it to the dealership and it was the cruise control switch that was faulty..
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
Octomus
Sep 3, 2015 11:40 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
