Small oil leak --- pan or sensor?
Old Sep 10, 2008 | 10:18 AM
desmo907's Avatar
I just got a 2008 40th Ann Ed (2k miles, used). In my garage i notice a small oil spot (size of a nickle) from under the car every few days. When I looked under from the driver side I reached to find some oil on what I thought to be the drain plug to the oil pan. I am assuming it is the oil pan being unfamiliar with the rotary (its somewhat square). But it is actually wet on what appears to be some sort of sensor as it has wires on it and the tape around it peeled off. So I am unclear on what it is -- maybe a oil sensor of some type? It doesn't seem to have a bolt pattern on it to tighten but maybe I didn't look close enough -- its tough to get under it. But where is the oil drain plug?
Thx,
Old Sep 10, 2008 | 10:28 AM
StealthTL's Avatar
Metatron
Drain is on passenger side, sensor is on drivers and mine leaked too.
S
Old Sep 10, 2008 | 11:37 AM
Jax_RX8's Avatar
Got Another Rotary
My oil pan sensor may be leaking as well - how do you fix, replace, tighten?
Old Sep 11, 2008 | 08:29 AM
desmo907's Avatar
I found a thread on it (below). Mine is very light (nickle size spot every 3-5 days or so) but I may call dealer as nothing hit is so I assume the warranty will cover it.
https://www.rx8club.com/showthread.p...hlight=10-7301
Is the oil leaking from where clip 10-259 is? If so the problem seems to be with the sensor (10-7301) which is inside the oil pan.
Old Sep 13, 2008 | 08:23 AM
Renesis07's Avatar
Vtak just kicked in yo!!
mine leaks too, I really dont let it bother me anymore, especially when I see the lake of trans fluid a little further down my garage every morning. I love this car.
Old Oct 14, 2008 | 12:18 PM
desmo907's Avatar
I did get the pan and sensor replaced under warranty by the dealer.
Apparently the 2008 40th Anniv Ed had parts perhaps keyed to the VIN (I was not sure what the service manager was saying nor did she, but they had to order the pan special).
Jesus Martinez
44
May 6, 2025 08:09 AM
RicerX1
Jan 11, 2016 05:59 PM
talonhart2
Aug 26, 2015 04:14 PM
eazzyg
Aug 12, 2015 09:09 PM
eazzyg
Aug 10, 2015 10:32 PM
