Fabulous
09-09-2008, 05:57 AM
Need Help!
My car suddenly jerk (kind of suddenly loss of fuel or air) at every 7500 rpm. Only @ 7500rpm.
it jerks and than suddenly continue to rev up......
DOMINION
09-09-2008, 06:03 AM
Could be a bad fuel pump. Search it up. From what I have read its a e-z fix :)
I would check my plugs. They could be bad not getting a good charge at the high RPM's.
Fabulous
09-09-2008, 09:00 AM
Will check it. But just thinking it is wierd because it only happen @7500rpm.
Could it be the injector which start @ 7500rpm
Fabulous
09-09-2008, 12:03 PM
Don't think it is an oil issue. I'm using Greddy (5W40) since day 1.
check your Aux port.
alz0rz
09-09-2008, 12:10 PM
how many miles on the car
Fabulous
09-09-2008, 12:29 PM
6 speed MT JDM. now about 45k miles.
Razz1
09-09-2008, 08:38 PM
Are you sure you are not hitting the rev limiter?
Fabulous
09-09-2008, 10:23 PM
RPM redline @ 9000. have been remapped by RE Amemiya.
no problem for years until lately....
Fabulous
09-10-2008, 09:13 AM
sorry, but what is the room fuse?
pull the room fuse?
StealthTL
09-10-2008, 09:29 AM
Footwell fusebox, marked 'room' controls constant power to the ECU.
.....but it sounds like a sticky actuator on the inlet manifold, to me.
S
Spinning Sushi
09-10-2008, 09:33 AM
Do this: http://www.rx8club.com/showthread.php?t=142852
That should fix your problem.
elysium19
09-10-2008, 10:33 AM
S
Same thought here.... Although I thought those come on earlier (6800), but it's possible you're not feeling it till a half-second later or something.
You can take that apart pretty easily and make sure the valves are opening smoothly.
Fabulous
09-10-2008, 10:58 AM
Done the above with the Liquid molly and compression check o.k.
Didn't help to resolve the 7500rpm jerk!!:banghead:
Fabulous
11-11-2008, 12:19 PM
Dear ALL,
I'm still having the problem. When I rev my rpm, it still hesitated @7500rpm (as though insufficient fuel for a 2 seconds) and then continue to climbing to 8500rpm and feeling lost of power.
It doesn't seem to be a mechanical problem. Do you think my ECU is the problem?
Anyone has experience this problem on 6MT JDM spec.
Need help urgently.
