When Do I Shift??
Old Nov 30, 2003 | 12:35 AM
shimm57's Avatar
When Do I Shift??
hello all
when i drive, i feel like i always have to be in 6th gear even for short distances. i use 6th gear when im at or above 36mph. i shift at 3000rpm (sometimes less) and just try to get to 6th gear every time i drive. is this bad for the car or am i doing the right thing for the best mileage?
someone also told me to shift at 5000rpm evry time instead of 3000rpm? is that good advice?
Old Nov 30, 2003 | 12:45 AM
loco4rx8's Avatar
BSG 75
Wow, unless you're just really obsessed with gas mileage, I'd say be a little more aggressive. You don't sound like you're having much fun in your 8.
I would not drive in 6th gear at 36 mph - seems like it would be close to lugging the engine, but I'm not sure since I've never tried it.
Shift at 4000 rpm if you want good gas mileage. That seems to be the consensus around here. But for goodness sake, take it up to 9000 once in a while. The car will love you for it. :D
Old Nov 30, 2003 | 01:01 AM
tribal azn2's Avatar
wtf 6th gear at 36mph?!!?? why??
Old Nov 30, 2003 | 01:07 AM
StealthTL's Avatar
Metatron
Cool Mileage?
What has mileage got to do with it?
Drive it like you stole it!
(And you will probably get exactly the SAME mileage....)
S
Old Nov 30, 2003 | 01:30 AM
Haze's Avatar
The owner's manual suggests that anything below 46 MPH is lugging the engine in sixth on a flat. On a hill you are seriously looking for trouble, but I can understand how you could do it. The car is so smooth at every rev it'll throw ya'.
Old Nov 30, 2003 | 02:23 AM
manbar's Avatar
Re: When Do I Shift??
Originally posted by shimm57
hello all
cool
Old Nov 30, 2003 | 02:35 AM
ptiemann's Avatar
doesn't the car feel very weak that way? I think you're overdoing it.. read the manual ~ page 5-7 has shift points.
What kind of car did you drive before or is this your first car?
-Peter
Old Nov 30, 2003 | 02:00 PM
shimm57's Avatar
this is my first, never driven manual b4, im new to it and i know pretty much nothing
Old Nov 30, 2003 | 02:31 PM
-=Zeqs=-'s Avatar
Ok dude...unless you are on the freeway cruising at 50 MPH...DO NOT cruise in your overdrive gear (6th). It puts a lot of strain on your engine and on your transmission as well. You could very well bust that gear if you floor it all of the sudden to get up a hill.
So just keep it at 5th. I've also noticed that the Renesis does pretty well on gas milage at about 3500 RPM or so.
Old Nov 30, 2003 | 03:29 PM
oosik's Avatar
I drive in 6th when my speed hits around 60. At that point, 6th gear at 3000rpm i'm doin 60, i have no hills to be worried about so it's comfortable. And with that gearing I"m less likely to go a whole lot faster without realizing it.
I find when i keep it in 5th or even 4th, my speed gets crazy and 4th gear at 60 is around the power band so kickin it up a notch is very easy...and fun.
I'm scared of tickets tho.
Old Nov 30, 2003 | 03:35 PM
VelocityRedRX8's Avatar
I drive the auto in 2nd or 3rd only around town. 2nd if I want to keep the revs up, 3rd if I'm cruisin. 2nd will go to > 75MPH @ redline. The car definitely feels sportier with the revs > 4000 RPM. Not good for MPG though.
Old Nov 30, 2003 | 06:12 PM
Aesculapius's Avatar
Finally have my 8!!
No sweat....I was there a few years ago.
A simple rule to start with that works with MOST cars:
Gear number = Speed / 10
So, if you are cruising at 40mph, then about 4th gear is a good choice. You really shouldn't be below 2000 RPM when cruising.
Keep trying different things and you will get the hang of it in no time. Before long, you won't even have to think about it....it will become automatic. :D
Cheers!
Old Nov 30, 2003 | 10:16 PM
red_rx8_red_int's Avatar
Re: Mileage?
S
I don't. Mostly, I drive it like I stole and get between 13 and 15 mpg. On the other hand, if I drive all highway at 80-90, (with some spirited spurts :D ) I can get low 20s.
Old Dec 1, 2003 | 07:59 AM
JmurphRx8's Avatar
why would you do that...its completely unnecessary...at around 36 mph im in like 3rd usually sometimes 4th
Old Dec 1, 2003 | 08:40 AM
guy321's Avatar
Humpin legs and takin nam
Cheers!
You can go 102 in 4th gear in this car!
Old Dec 1, 2003 | 08:42 AM
DocTorCold's Avatar
Shimm 57
Because of the rotary design of the renisis engine you really should be driving the RX8 like a motor cycle. There is an optimum rpm for optimum fuel economy for particular engine types. DOHCs are typically around 3000 RPM. The optimum RPM for the renisis is around 5500 (like a motorcycle). The only time you should shift below 5500 is when you're still in the first 300 miles during the breakin period (read your owner's manual, you know the thing in the glove compartment that has all the pages). Also, a tip that I picked up from a web page on performance fuel economy, do not break with the engine by riding the clutch. Use your breaks like you should and downshift only to maintian engine momentum. Breaking with you engine wates fuel because it consumes the natural kinetic energy of the ingenius renisis design.
Old Dec 1, 2003 | 09:39 AM
Finally have my 8!!
I was referring to cruising.....why would you want to stay in 4th at 102mph?
Old Dec 1, 2003 | 12:08 PM
pelucidor's Avatar
Pure Gold
I think that at least once a day you should hit 9500rpm in 1st (45mph) and maybe 2nd as well (68mph). No other production car in the world can do this - make the most of it.
BTW the manual suggests the following gear changes for maximum fuel economy (to stay in the 2000-2750 rpm range):
1-2 at 14mph
2-3 at 21mph
3-4 at 28mph
4-5 at 35mph
5-6 at 42mph
so there is no point in moving to 6th below 42mph (I usually was in 6th at 45-50mph when just cruising in traffic).
Old Dec 1, 2003 | 12:13 PM
guy321's Avatar
I know you were referring to cruising. You wouldn't, thats about the time to shift out of 4th.
Old Dec 1, 2003 | 06:53 PM
Finally have my 8!!
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
XianUnix
Sep 29, 2015 03:48 PM
