light, question please
Old Sep 7, 2008 | 06:37 AM
yenphi's Avatar
I got my car used so I did not have manual, for a whole week, the light right below the L as low oil indicator showing up after the car starts, it is there for 10 to 20 seconds then off, what is it ? and I also try to down load the manual but get no luck, anybody please hepl. thank.
Old Sep 7, 2008 | 07:46 AM
invasion08's Avatar
I would check your oil first. The Oil should be between the top dot and top line. If there is enough oil and the light still comes on the oil level sensor may be bad. Mazda as a TSB for it http://www.finishlineperformance.com...13-04-1341.pdf
Old Sep 7, 2008 | 09:15 AM
ken-x8's Avatar
Definitely check the oil. If your car is old enough that the dipstick does not have dots, the oil level should be closer to the top line than the bottom. Preferably right at the top line.
What year is your 8? Where have you been trying to download the manual?
Ken
Old Sep 7, 2008 | 01:37 PM
yenphi's Avatar
04 6mt, under the L letter, couting from the bottom is service engine light, battery light, oil light and ? light, the ? light is what it is for? , I just check, the oil level is perfect, closes to the top hi line.
Old Sep 7, 2008 | 03:15 PM
04RX8man's Avatar
Rotary Powered Countryboy
what does the light look like? I didn't get a manual either and i think i know what you mean but mine is when i rev it up alot (in N had to test somethign)
Old Sep 7, 2008 | 04:18 PM
yenphi's Avatar
rectangular shape with a roof on the top, look like a house?
Old Sep 7, 2008 | 04:56 PM
04RX8man's Avatar
yeah i know the exact problem just happened today I left work and the CEL was on I was like WTF so got home tightened the gas cap (filled up last night) disconnected the battery and light went away so I reved it up to redline just to make sure everything was running ok and the "house" light came on then shut off at like 6k did it again and it happened again...but now it didn't do it... i didn't get a manual either so it woujld b nice to know what this means?
Old Sep 7, 2008 | 04:57 PM
Juice's Avatar
I made some poos
That is the low engine coolant light. Check your coolant level.
Also note that if coolant is at normal level then the sensor could be going bad. It is a know problem and there are a couple of things you can do:
1. Replace the coolant reservoir tank since the sensor is built into it.
2. The other is to unplug the sensor, and check your coolant level regularly.
Old Sep 7, 2008 | 05:07 PM
04RX8man's Avatar
^that's what I thought it might b but I was not positive about it...i know mine was getting towards the ADD line on the resivour so when she cools down i'lll go check it out
Old Sep 7, 2008 | 05:23 PM
greg985's Avatar
The 337
its most likley the battery light, if it comes on after he cranks it then goes off. The batter is weak after cranking the engine and then goes off once the battery gets recharged
maybe?
Old Sep 8, 2008 | 07:40 AM
yenphi's Avatar
thanks, I will check my coolant, i think it is hard to see min-max line on the resevoir, but anyway I will add some thing in.
Old Sep 8, 2008 | 07:47 AM
*shurgs*
read your manual
if u dont have one. FIND IT ONLINE ! Argh !
Old Sep 8, 2008 | 08:36 AM
yenphi's Avatar
I tried online but been unlucky to find one, any link?
Old Sep 8, 2008 | 08:37 AM
ken-x8's Avatar
The tank is translucent. If you shine a good light down from the top (put a flashlight right on it),then look at the side, you can see the level a lot better. Not perfect, since your view is from an angle, but well enough to check the level.
Ken
Old Sep 8, 2008 | 08:39 AM
ken-x8's Avatar
If you're in the US, mazdausa.com. Register in the owner's section, and you'll be presented with a link for the manual for your year.
Ken
Old Sep 8, 2008 | 10:51 AM
yenphi's Avatar
thank for the infor all of you.
Skyl3r
Dec 2, 2019 04:51 PM
Kahl
Aug 20, 2015 11:49 PM
tgaffner
Aug 20, 2015 10:55 AM
dancingdan42
Aug 19, 2015 09:29 AM
Stubbs
Jul 28, 2015 09:23 PM
