Did I get a free de-carb?
Old Sep 6, 2008 | 05:33 PM
Old Rotor's Avatar
I have a '04 A/T with 36K all up to date on "TSB's" and service. I have noticed that the power was off mostly on the top end. I changed plugs, coils, wires, air filter, cleaned A/F, no change. So I have a friend that is a master mechanic and he ran a compression test(with the proper Mazda equip). The front was 6.7 at 240rpm and rear was 8.2 at 245rpm. His ALLDATA-online said 6.9 was min and 1.0 difference between rotors was max. This is why I brought it to my Mazda dealer to have them run a compression test. They said they would run CARBON REMOVAL PROCEDURE($300+ if needed) if it tested low. I picked it up($176 for test and oil and filter) and the compression tested at front 8.4(no rpms given?) rear was 8.8. It's fine they say did not need de-carb he also added its 6.5 min and 1.5 max between rotors is Mazda specs.......hmmmm? I've driven it a some and it seems a little better. Hmmmm.....my service rep said they called Mazda....why? Maybe to get ok on free de-carb. I will have to check it again someday.
Old Sep 6, 2008 | 05:36 PM
laythor's Avatar
I zoom therefore I am.
I would think they didnt decarb since that actually takes time... weird.
Old Sep 6, 2008 | 05:45 PM
kersh4w's Avatar
Hit & Run Magnet
the de-carboning procedure is free.
Old Sep 6, 2008 | 05:59 PM
Old Rotor's Avatar
It was at the dealer six hours. They told me it's free if it's still on the 4yr-50K mile warranty, mine's 5yr this mo. You are correct this is what is on the "TSB"...
WARRANTY INFORMATION
NOTE:
• This warranty information applies only to verified customer complaints on vehicles eligible for warranty
repair.
• Warranty term coverage is 8 years (96 months) from the original warranty start date, with a 100,000
mile mileage limitation.
• Additional diagnostic time cannot be claimed for this repair
Old Sep 6, 2008 | 06:43 PM
Brettus's Avatar
Boosted Kiwi
sounds fishy - get your mate to check it again .......
Old Sep 6, 2008 | 07:28 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah sounds a little fishy 2 me also
Old Sep 6, 2008 | 09:15 PM
Old Rotor's Avatar
That was my feeling at first....fishy. Now I will have to drive it a little too tell. It does say to "verified customer complaints" and It only had about 3-4 additional miles on so I don't know. My mechanic friend lives about an hour and a half away and is a very busy guy, so I don't know when that will happen. At least I have three more years on engine and have problem reported.
Old Sep 6, 2008 | 11:48 PM
Hey Old Rotor, when it comes to a stop (say, red light), did ur motor ever dip below 700 rpm ?
mine did and it went to around 500 rpm then pop back up. I think my motor is going down
Old Sep 7, 2008 | 12:20 AM
Old Rotor's Avatar
No never that low. I saw about 750rpm and felt a vibration. Get the de-carb done! I put some reg 87 in today and took the throttle body by pass out. This was put in to stop MIAC(Marble In A Can)ping. It was about 100F here today and I pushed it hard and did not hear preignition. With less carbon glowing hot no MIAC. I have had to run prem 91 for the past 16K miles(two years) during the hot months only to stop MIAC. I have to do more high RPM test to prove it to myself but feel pretty good about it.
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Vendor Classifieds
Oct 14, 2015 12:29 PM
