Cloudy Headlights
Old Sep 5, 2008 | 09:53 AM
enthegen's Avatar
wfc#046
Cloudy Headlights
I have a 04 rx8 and the headlight lens on my car has somewhat of a fog/cloudy places on the inner side of the outter lens (if that makes sense). My question being is it possible to take the headlight assembly apart and be able to clean this out? Or is it just something where id have to replace the entire housing?
Old Sep 5, 2008 | 09:59 AM
Outkast187's Avatar
If the plastic is cloudy, its on the outside. If is moisture its on the inside. If its just cloudy, you can wetsand with 1500grit, then 2000, and then 2500 and then polish. High speed buffers need great care, they will burn into plastic in a second. Hand polishing takes more effort but is possible. You can practice on junk plastic first.
Old Sep 5, 2008 | 10:10 AM
enthegen's Avatar
wfc#046
Its not moisture but it looks maybe like it was where moisture was at one point. Im certain its on the inner side of that housing. Its going to be something I am going to have to open the housing up if thats possible.
Old Sep 5, 2008 | 12:02 PM
laythor's Avatar
I zoom therefore I am.
It is possible to get bake off the lens, clean it, then glue it back. It just takes ***** of steel. Search and you'll find a few threads about people who've done it.
Old Nov 10, 2010 | 12:08 PM
wrightcomputing's Avatar
Made in England
This is a post of how I did mine using the Meguires headlight restoration kit it took less then 20 mins, I would try this first before you take it appart
https://www.rx8club.com/showthread.ph...=1#post3779579
Shankapotamus3
Mar 14, 2021 03:53 PM
drlubell
Sep 26, 2015 11:58 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
