is this a good spot?
Old Sep 3, 2008 | 05:27 PM
db_8's Avatar
Exclamation is this a good spot?
to put the jackstand for the rear side of the car?
and i'll probably use the "armpit" for the front jackstand as MM described in the other thread. didn't find any for the rear side so i'm asking. thanks!
Old Sep 3, 2008 | 05:29 PM
CyberPitz's Avatar
Huge hole is huge
Looks like it should work, bu t I'd rather find a flat surface, since I'm a worry wart.
Old Sep 3, 2008 | 06:07 PM
Schimmle's Avatar
El Terrifico
Wouldn't that place work perfect. Its perfectly shaped to the stand itself.
Old Sep 3, 2008 | 06:09 PM
04RX8man's Avatar
Rotary Powered Countryboy
Uh.....what ru trying to do? It could b in the way of what you're trying to do hard to know without more info
Old Sep 3, 2008 | 06:13 PM
db_8's Avatar
trans & differential fluid change Ü
one more thing, is it alright to leave it on stands overnight if you haven't finished the job or should i just lower it?
ktec
RX-8 Show and Shine
Oct 1, 2015 11:20 PM
IB Cristina
West RX-8 Forum
Aug 20, 2015 08:52 PM
thedragonrotar
Jul 22, 2015 08:46 PM
Belalnabi
Jul 17, 2015 07:48 PM
