View Full Version : Front Plate has to go!!!!
I personally feel that the front number plate has to be put somewhere else. Not right in front taking up almost 85% of the god damn "mouth"! Anbody knows if its legal to just do up a smaller plate and stick it just below the Front Mazda Logo?
Try to imagine wad im toking about on top.....removing the r magic plate totally. putting a smaller one just below the logo..
Any one of u know the regulations e.g dimensions, reflectivity etc etc.....
Too lazy to go search....
CHEERS
Fab 8 11-29-2003, 02:59 AM One of our forum members has done this - Spyder766
Check out his car here (http://www.rx8club.com/showthread.php?s=&threadid=10542&highlight=singapore)
Ok thanks a lot...
And spyder if u ever get to read this thread......Ur plate legal?
Or just biting the bullet for 3 years b4 inspection?
M-ster 11-29-2003, 07:49 AM This was what I did on my car Miata.
I couldn't pass the VICOM test, but manage to drive it around without any problem.
OK thanks. Ye, i just did the same to mine. Sticker thingy....Hopefully no eyesore to TP.
Fingers crossed!
M-ster 11-30-2003, 04:42 AM Neon,
could you post a pix after you have done? I probably wanna do it as well, but will be great to see how it look. I think 2f2f got his mazda logo removed. So are you gonna do the same?
Fab 8 11-30-2003, 04:55 AM How do these go through carparks that identify the number plates, such as Tangs? Any problems?
dru8999 11-30-2003, 05:17 AM Hi Fab8, were u at Raffles City Shopping Ctr tis morning at abt 10:30am? Thought i saw ur car. HEHE.
Fab 8 11-30-2003, 06:21 AM Yup, that was me :)
i wil be doing it tomorrow. once done, will post a pic.
2F2F, how much u paid to patch them up and repaint? i'm thinking of doing that, the logos too fugly.....
Mr Rabbit 11-30-2003, 08:15 PM Hi Neon.
It IS legal. Under the Road Traffic Act, legal plates have to be of a certain size (i.e. the character) & colour.
Interestingly, the characters on the plate can be either 3-d or flat; same goes for the plate itself.
But check for how reflective the plate turns out - that's the only REAL problem u could get into.
I'll retrieve the exact provision if u like.
Me kept a copy for four-point harness in me previous ride. Be ready to produce in event that TP stop u.
Mr Rabbit 11-30-2003, 08:17 PM BTW M-Ster, I'm surprised u couldn't clear the VICOM. When was your test?
Fab 8 11-30-2003, 08:24 PM Hi Rabbit, thanks for the info! Never knew the pasted on plates are legal.
For black cars, the plate will probably blend into the car colour. That will look cool, I think.
Mr Rabbit 11-30-2003, 08:33 PM At risk of being a nag; watch the size of the characters & level of reflectiveness.
By way of general estimation, u should be able to squeeze the characters under the mazda logo as Neon wants to do.
Mr Rabbit 11-30-2003, 08:44 PM Red (car) & black (plate) is quite striking!
On the other hand, u could paint ur RX black!
dru8999 11-30-2003, 08:44 PM Well another issue that cross my mind is whether LTA or TP will object to paste-on-plate is the fact that these plates maybe not be at the same angle as plates mounted in the normal manner as plate will not be perpendicular to the road n thus be able to evade the red-light-cameras or speed cameras. Would anyone like to add their views b4 all owners rush out to get plates which would not be approved. Tks!
Mr Rabbit 11-30-2003, 08:47 PM With respect, not quite an issue since both cameras mentioned flash the rear of the car - not the front.
Mr Rabbit 11-30-2003, 08:50 PM Me assume that nobody is gonna paste 'plates' on the rear. But even if u do, same thing applies.
The kiasu (love that word!) thing to do would be to write LTA & ask.
M-ster 11-30-2003, 09:15 PM Originally posted by Mr Rabbit
That was sometime middle of last year.
dru8999 nail half the reason, normally a stick on plate will not be on the right angle. The other reason would be, stick-ons are normally non-reflective material, I think the either the numbers or the base plate has to be of a reflective finish. Thus - reflextive YELLOW/WHITE base with non-reflex NUMBERS or reflextive WHITE NUMBERS on NON-REFLEX BLACK NUMBERS
Ok just did mine. Note it definitely fails VICOM. Moreover mine is white backgrd--->worse (on Black 8)
Apologies for the pix, taken with V200. :D
Oh b d way, its a sticky type (So called German sticker or wudever...) Easy to peel out too when 3 years up and no eye sore to TPs....
Fab 8 12-01-2003, 07:46 AM Can take a better photo to appreciate the effect? Many thanks!
M-ster 12-01-2003, 08:28 AM can't you have it black base with white text?
do you need to remove the whole front bumper to get the plate off?
concur with Fab8 about the picture quality:)
cheers
Ok wil get a better pix once taken wif digicamera.
Of coz can have the standard black n white lettering. Personal preference i guess....
CHEERS
Mster - U do not need to remove the bumper. Just simple 3 nuts (phillips) for mine. Base plate differs from PIs i guess.
Mine has two infront and 1 behind the mesh but easily reachable by hand via the openings just below.
Hi Neon,
Sorry, only ready yr message. FYI, I've hesitated to remove the logo bcos U need twice the paint work to cover smoothly. If u putty the holes....they will sink after awhile...then U need to putty again. & of course U need to spray the entire piece to aovid any fading shades..
Now, still quite happ with my GDB GT wing with front lips & back lower bumber spray painted.
cheers
Mr Rabbit 12-02-2003, 09:17 PM Originally posted by Neon
Hi again. Why would it definitely fail VICOM? And FYI white background for the front is legal. Rear has to be black or yellow.
Cuz its non-reflective and i believe LTA hates stickers :D
Weets 12-03-2003, 01:28 PM From my personal exp, yes sticker fails Viacom though you might not fail the whole inspection. My inspector was nice enough to just tell me remember to bring my front plate next time (realy forgotten abt it) and bolt it on before the inspection.
Hope this helps.
Agree. My EG9 had the same problem. However, my inspector told me go change and then come back. So what i did was drove out park at the side and screw on my original standard plates. Smoked a couple n drove back in.....PASS :D
Hope this helps too..... =_=)V
